Can't pass trafic over link
I just recieved our first 532 boards and SR5 cards. I am new to this equipment but know my way around rf quite well.
I have configured everything that I can see in the wireless section of the software but I can’t ping accross the wireless link. The 2 boards are associated. And this is a simple P2P bridge, no routing, nat or any thing else as it is already taken care of on an other router.
Is threre someting fundemental that I have to do elsewhere to get this to work. A bridge or route of some type between the eth1 and wlan1 ?
Try bridging the ethernet and wireless card interface and move your ip address to the bridged interface for both routerboard 532. This will enable you to have a bridged link between the 2 routerboard.
You will have a better (transparent) bridge if you implemented EoIP or WDS, i prefer WDS but both are cool.
Do read the Mikrotik Reference manual , Mikrotik is as robust and complex as Cisco yet most cost effective.
Do I still need to bridge the eth1 and wlan1 on each side of the link? The documentation seems pretty good but there are no exaples to get started with.
Erik
I’ve got the same problem with “starting” with mikrotik the answer:
http://www.mikrotik.com/docs/ros/2.8/howto/howto.content
See section: How to Transparently Bridge two Networks?
