I have three ports connected to a vmware server as a trunk port. I have a vm inside and I am unable to ping it on the same vlan.
port 1-3 is for vmware port 6 is on vlan 21 and there is vm inside the vmware server also in vlan 21 and I cant ping across.
add l2mtu=1598 name=bridge-native
add l2mtu=1598 name=bridge-public
add l2mtu=1598 name=bridge-trunk
/interface vlan
add interface=bridge-native l2mtu=1594 name=vlan-21-native vlan-id=21
add interface=bridge-public l2mtu=1594 name=vlan-50-public vlan-id=50
add interface=bridge-trunk l2mtu=1594 name=vlan-21-trunk vlan-id=21
add interface=bridge-trunk l2mtu=1594 name=vlan-50-trunk vlan-id=50
add bridge=bridge-native interface=ether6
add bridge=bridge-public interface=ether7
add bridge=bridge-public interface=ether8
add bridge=bridge-native interface=ether9
add bridge=bridge-native interface=ether10
add bridge=bridge-trunk interface=ether1
add bridge=bridge-trunk interface=ether2
add bridge=bridge-trunk interface=ether3
add bridge=bridge-trunk interface=ether4
add bridge=bridge-trunk interface=ether5
add address=192.168.21.1/24 interface=bridge-native
add address=192.168.50.1/24 interface=bridge-public
set allow-remote-requests=yes
Rudios
October 10, 2013, 12:35pm
2
I would create this diffenrently
Create VLAN interfaces on the ether interfaces that needs to act as trunk
And put these VLAN interfaces into designated bridges
/interface vlan
add interface=ether1 l2mtu=1594 name=vlan-21-e1 vlan-id=21
add interface=ether1 l2mtu=1594 name=vlan-50-e1 vlan-id=50
add interface=ether2 l2mtu=1594 name=vlan-21-e2 vlan-id=21
add interface=ether2 l2mtu=1594 name=vlan-50-e2 vlan-id=50
add interface=ether3 l2mtu=1594 name=vlan-21-e3 vlan-id=21
add interface=ether3 l2mtu=1594 name=vlan-50-e3 vlan-id=50
add interface=ether4 l2mtu=1594 name=vlan-21-e4 vlan-id=21
add interface=ether4 l2mtu=1594 name=vlan-50-e4 vlan-id=50
add interface=ether5 l2mtu=1594 name=vlan-21-e5 vlan-id=21
add interface=ether5 l2mtu=1594 name=vlan-50-e5 vlan-id=50
add bridge=bridge-native interface=vlan-21-e1
add bridge=bridge-native interface=vlan-21-e2
add bridge=bridge-native interface=vlan-21-e3
add bridge=bridge-native interface=vlan-21-e4
add bridge=bridge-native interface=vlan-21-e5
add bridge=bridge-public interface=vlan-50-e1
add bridge=bridge-public interface=vlan-50-e2
add bridge=bridge-public interface=vlan-50-e3
add bridge=bridge-public interface=vlan-50-e4
add bridge=bridge-public interface=vlan-50-e5
set allow-remote-requests=yesAnother important thing his how your virtual network is configured
Is there a better way of doing this cause this seems like the more vlans I add this config will grow exponentially. In cisco if I allow all vlans on the trunk then it is just one line of code on the interface.
Also, what is wrong with my config, why cant I ping from vlan 21 on port 9 to a vm also on vlan 21. The VM is inside the vm host which is connect to ports 1-3 as a trunk.
Rudios
October 11, 2013, 4:59pm
4
I looked closer to your config.
It might help adding the vlan interfaces vlan-21-native and vlan-51-public to the designated bridges
Rudios
October 11, 2013, 5:02pm
5
Thinking again. You do not need the native and public vlan interfaces and put the vlan interfaces from the trunk bridge to the individual bridges
not sure if I understand what you mean
so remove
/interface vlan
but then what do you mean add the vlan interface to individual trunks?
Rudios
October 11, 2013, 10:16pm
7
No. Remove the other two VLAN interfaces.
Then add the interfaces you mentioned into the bridge-native and bridge-public
