Hey, I’m really new to all this!
I have a NanoStation5 as AP and I’m trying to connect to it with a Groove Metal SSHP as station. I can connect to the NanoStation using another NanoStation, the connection so far is good. I’ve assured the NS5 is using the 811.2 protocol and there’s no enabled Nstreme. So it’s simply:
Internet (gateway 10.1.1.1) <—> NS5 AP (10.1.1.254) <—> Groove Metal (10.1.1.123) <—> My Computer (10.1.1.2)
Using winbox for the config, apparently it succefully registers (registration tab on Wireless Tables) and in the IP routes window it says the gateway is “reachable”, but I can’t even ping the AP from the groove or connect to the internet. Everything timeouts and I can’t figure out why!
Here’s the exported file:
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] country=brazil disabled=no frequency=5660 ssid=\
"AP"
add bridge=bridge1 interface=wlan1
add address=10.1.1.123/24 interface=bridge1 network=10.1.1.0
set servers=8.8.8.8
add distance=1 gateway=10.1.1.1
Thanks!
