Cant ping by hostname outside mikrotik via IPIP tunnel
So i created an IPIP tunel between 2 locations, NAT and routes are properly added and i can ping without issue networks form both sides, enter network shares, RDC etc.
Problem is i cant access any of them by hostname of server/computer. Mikrotik from its console can ping by name without issues, but i cant ping it from my PC.I tried also adding static DNS and all pcs already point to mikrotik as DNS server.
Any idea what else i can do to fix it?
EDIT:I did manage to get ping by adding servername.local into DNS static, than when i ping servername.local i get ping, but there is a bit delay before it resolves compared to direct ip.
But i need solution so i can ping any PC on opposite side tunel network.
