Can't ping devices on the same network
Hey everyone!
I have MikroTik wAP. I have configured hotspot, so my network diagram looks like that:
My Raspberry Pi is added to hotspot’s “IP Bindings” section to bypass authorization.
From WinBox I can see that both my PC and Pi are connected and IP addresses assigned as shown on a diagram above.
Both devices can go online and serf internet, but I cannot access the other devices. When i try to ping from my laptop “ping 10.0.0.2” i always get “Request timed out.” and from my Pi I can’t ping PC(10.0.0.254) as well.
Please help me to understand what am I missing in my configurations. I am newbie to internet setups, but i think something is wrong either with routing or my firewall.
Please see my configurations(if you need anything else, ask me, i ll post it here):
[admin@MikroTik - office] /ip firewall nat> /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     10.0.0.1/24        10.0.0.0        wlan1
 1   10.1.1.1/24        10.1.1.0        guest-wifi
 2 D 172.30.10.94/24    172.30.10.0     ether1
[admin@MikroTik - office] /ip firewall nat> /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          172.30.10.1               1
 1 ADC  10.0.0.0/24        10.0.0.1        wlan1                     0
 2 ADC  10.1.1.0/24        10.1.1.1        bridge-guest-wifi         0
 3 ADC  172.30.10.0/24     172.30.10.94    ether1                    0
[admin@MikroTik - office] /ip firewall filter> print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; allows user manager to work with local hosts
      chain=input action=accept src-address=127.0.0.0/24 log=no log-prefix=""
 2  D chain=forward action=jump jump-target=hs-unauth hotspot=from-client,!auth
 3  D chain=forward action=jump jump-target=hs-unauth-to hotspot=to-client,!auth
 4  D chain=input action=jump jump-target=hs-input hotspot=from-client
 5  D chain=input action=drop protocol=tcp hotspot=!from-client dst-port=64872-64875
 6  D chain=hs-input action=jump jump-target=pre-hs-input
 7  D chain=hs-input action=accept protocol=udp dst-port=64872
 8  D chain=hs-input action=accept protocol=tcp dst-port=64872-64875
 9  D chain=hs-unauth action=return dst-address=10.0.0.2
10  D chain=hs-input action=jump jump-target=hs-unauth hotspot=!auth
11  D chain=hs-unauth action=reject reject-with=tcp-reset protocol=tcp
12  D chain=hs-unauth-to action=return src-address=10.0.0.2
[code][admin@MikroTik - office] /ip firewall nat> print
 0  D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
 1  D chain=hotspot action=jump jump-target=pre-hotspot
 2  D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
 3  D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
 4  D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst dst-port=80
 5  D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst dst-port=443
 6  D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
 7  D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
 8  D chain=hs-unauth action=return dst-address=10.0.0.2
 9  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
10  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
11  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
12  D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp dst-port=443
13  D chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
14  D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
15  D chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
16 X  ;;; place hotspot rules here
      chain=unused-hs-chain action=passthrough
17    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
18 X  ;;; masquerade hotspot network
      chain=srcnat action=masquerade src-address=192.168.88.0/24 log=no log-prefix=""
19 X  chain=srcnat action=masquerade out-interface=wlan1 log=no log-prefix=""
STOP DUPLICATING POSTS
http://forum.mikrotik.com/t/impossible-to-ping-devices-within-same-network/116943/1
Sorry man, but what shall i do if i’, not getting any replies and it seems that forum is not very active :confused:
Add a post in original topic/thread to bump it to the top again.
