Please, help me about the following problem:
I Have 3 NICs on my PC with RouterOS as follow:
LAN1: 192.168.0.1(192.168.0.0/24)
LAN2: 192.168.1.1(192.168.1.0/24)
WAN: X.X.X.X (X.X.X.X.)
I can’t ping from a host on LAN1 to LAN2.
I just can ping to 192.168.0.1 and 192.168.1.1 but not to another host in the Network
From the router i can succesfully ping to any Host in ahy LAN
The most likely cause given what little information you have given is that you’re dealing with Windows Vista or 7 hosts that have firewalls configured. The default network profile in those operating systems allows ICMP echo requests from the same network, but not from other networks. So pinging from the other LAN fails, pinging from the router works as by default it will pick the closest interface to the destination as a source, which the host would of course perceive as being on the same network. You can prove that by pinging hosts from the router and manually setting the source address to the IP address of the LAN interface the host is NOT behind. If that tests fails edit the host firewall policies and you should be good to go. You could also source NAT the two LANs but that’s a very ugly solution.
3 A S ;;; added by setup
dst-address=0.0.0.0/0 gateway=190.120.X.X interface=WAN
gateway-state=reachable scope=255 target-scope=10
[admin@MikroTik] > /interface print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R LAN_SM ether 0 0 1500
1 R WAN ether 0 0 1500
2 R LAN_IGO ether 0 0 1500
[admin@MikroTik] > /ip firewall export
/ ip firewall mangle
add chain=prerouting src-address-list=sm action=mark-connection
new-connection-mark=sm_cnn passthrough=yes comment="" disabled=no
add chain=forward connection-mark=sm_cnn action=mark-packet
new-packet-mark=sm_traffic passthrough=no comment="" disabled=no
/ ip firewall nat
add chain=srcnat out-interface=LAN_IGO action=masquerade comment=""
disabled=yes
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s
tcp-established-timeout=1d tcp-fin-wait-timeout=10s
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m
tcp-syncookie=no
/ ip firewall address-list
add list=sm address=192.168.1.0/24 comment="" disabled=no
/ ip firewall service-port
set ftp ports=21 disabled=no
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set gre disabled=yes
set pptp disabled=yes
If you can ping both LAN interfaces then obviously routing is working. Also, bridging and routing are completely different things.
Disable all host firewalls, try again. Your host firewalls are blocking ping from all networks they aren’t directly connected to.
