Can't ping Hostname from VPN
Hi
I have an RB951 which is configured as a vpn server. I can access all the computers on the lan by ip but not by hostname.
The NSLOOKUP command if I use the ip answers the name, but if I use the name I have no response. only works with the hostname of the router
I appreciate if someone gives me a hand with this-
Thank you!
In advanced tcpip settings of your vpn connection ad your domain…
Hi Satman, ty for the reply,
In this particular client, it does not have a domain or a DNS server, I do everything using the mikrotik. In my office I have a dns server and a similar router with which I can make queries by hostname
I also have the same problem. I can Ping computers and hostname/computer name from vpn but when trying to Ping computer name. No reply.
When doing a tracert from vpn I get the ip plus hostname.
I also added a static hostname/computername corresponding to its ip in dns.
