EDIT: Reposting in the general forum, as this didn’t fit the forwarding forum.
I can’t ping both ends of a /30 between 2 interfaces, connected by an ethernet cable if one is running os 6 and the other os 7. Neither side can ping the other.
If they both run ros 6, or both run ros 7, this issue is resolved. But if one is 6, and the other is 7, no packets are exchanged.
I’ve torn my hair out over this for the last couple days, and (feel with my knowledge) that this is an issue due to software and/or a configuration issue I’m overlooking when running ros 7?
From my understanding, this shouldn’t be related to http://forum.mikrotik.com/t/ip-route-ros7-between-ros6-problem/165004/1
I have also replicated this issue with an RB4011, running ros 7.8 current, with my hAP device running 6.49.7 and have experienced the same result. I’ve set this configuration up many times, but there has to be something I’m missing in ros 7?
Export from os 7 (Both ends can ping each other)
# mar/24/2023 16:14:30 by RouterOS 7.8
# software id = 01KC-7PT7
# model = RB952Ui-5ac2nD
# serial number = B8C80AB7FF5C
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/interface lte apn
/ip hotspot profile
add bridge=bridge1 ingress-filtering=no interface=ether2
add bridge=bridge1 ingress-filtering=no interface=ether3
add bridge=bridge1 ingress-filtering=no interface=ether4
add bridge=bridge1 ingress-filtering=no interface=ether5
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.19.2/30 interface=ether1 network=192.168.19.0
/ip ssh
set forwarding-enabled=remote
/system clock
set time-zone-name=America/Los_Angeles
Export from same mikrotik as above, but running os 6 (Can’t ping other side).
# mar/24/2023 16:29:10 by RouterOS 6.49.7
add name=bridge1
/interface wireless
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pass\
word,web,sniff,sensitive,api,romon,dude,tikapp"
/ip ssh
/system clock
Lastly, here’s the configuration for the other side I’m trying to ping.
# mar/24/2023 22:51:38 by RouterOS 7.3.1
# software id = 37E0-5QQI
# model = RB924i-2nD-BT5&BG77
# serial number = E9C70E274077
add admin-mac=2C:C8:1B:87:79:E6 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=WPA supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united states" disabled=no distance=indoors frequency=auto installation=indoor mode=station-pseudobridge-clone rx-chains=0 security-profile=WPA ssid=XR2 \
station-bridge-clone-mac=2C:C8:1B:87:79:E6 tx-chains=0 wireless-protocol=802.11
/iot bluetooth
set bt1 name=bt1 random-static-address=CA:C0:2A:19:23:F4
/port
set 1 baud-rate=9600
/interface ppp-client
add apn=m2mNB16.com.attz data-channel=2 default-route-distance=2 dial-on-demand=no disabled=no info-channel=2 name=ppp-out1 port=modem
/ppp profile
set *0 use-ipv6=required
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge disabled=yes ingress-filtering=no interface=ether1
/ip settings
/ipv6 settings
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=ppp-out1 list=WAN
set auth=sha1,md5
/iot bluetooth scanners
set bt1 disabled=no
/iot modbus
set disabled=no
add address=192.168.19.1/30 interface=ether1 network=192.168.19.0
/ip dhcp-client
add add-default-route=no interface=bridge use-peer-dns=no
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set servers=208.67.220.220
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.10 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ipv6 dhcp-client
add add-default-route=yes interface=ppp-out1 pool-name=ipv6 request=prefix
/system clock
set time-zone-name=America/Chicago
/system gps
set channel=1 init-channel=2 init-string="AT+QGPSCFG=\"outport\",\"usbnmea\";+QGPSCFG=\"priority\",0;+QGPS=1" port=modem set-system-time=no
/system identity
set name=KNOT
/system ntp client
set enabled=yes
/tool mac-server
/tool mac-server mac-winbox
