here is my /export
nov/28/2021 15:31:22 by RouterOS 6.49.1
software id = EQ9Z-XA1M
model = RB760iGS
serial number = D4500DE52C68
add comment="LAN Bridge" name=bridge1-LAN
set [ find default-name=sfp1 ] name=Sfp-1
set [ find default-name=ether1 ] comment=Connectel name=WAN1
set [ find default-name=ether4 ] comment=Brain name=WAN2
set [ find default-name=ether3 ] comment="Connectel Backup" disabled=yes
name=WAN3
set [ find default-name=ether5 ] comment="Brain Backup" disabled=yes name=
WAN4
set [ find default-name=ether2 ] comment=LAN name=ether2-LAN
add name=WAN
add name=LAN
/ip firewall layer7-protocol
add comment="Block Bit Torrent" name=layer7-bittorrent-exp regexp="^(\x13bitt
orrent protocol|azver\x01$|get /scrape\?info_hash=get /announce\?inf
o_hash=|get /client/bitcomet/|GET /data\?fid=)|d1:ad2:id20:|\x08'7P\)[
RP]"
/ip ipsec peer
This entry is unreachable
add name=L2TP passive=yes
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add comment="LAN DHCP" name=dhcp ranges=192.168.1.11-192.168.1.126
add comment=WAN name="dhcp_pool1 WAN" ranges=103.105.208.226-103.105.208.230
add address-pool=dhcp disabled=no interface=bridge1-LAN name=dhcp1
/ppp profile
add address-list="" local-address=192.168.1.10 name="l2tp vpn"
remote-address=dhcp
set *FFFFFFFE dns-server=8.8.8.8,8.8.4.4
/queue simple
add max-limit=256k/256k name="Sehar Mobile" target=192.168.1.28/32
add max-limit=1M/1M name="Burhan Sami Mobile" target=192.168.1.40/32
add max-limit=256k/256k name="Umar SEO Mobile" target=192.168.1.46/32
add max-limit=256k/256k name="Imtiaz Mobile" target=192.168.1.121/32
add max-limit=512k/512k name="Nosheen Mobile" target=192.168.1.35/32
add max-limit=512k/512k name="Ayesha Mobile" target=192.168.1.36/32
add max-limit=256k/256k name="Hafsa Mobile" target=192.168.1.38/32
add name="Mehroze Mobile" target=192.168.1.11/32
add max-limit=256k/256k name="Umar SEO " target=192.168.1.20/32
add max-limit=256k/256k name="Sania Mobile" target=192.168.1.17/32
add max-limit=256k/256k name="Hamza Mobile" target=192.168.1.31/32
add max-limit=256k/256k name="Rizwan Jilani" target=192.168.1.80/32
add name="Bilal Mobile " target=192.168.1.103/32
add max-limit=512k/512k name="kainat Mobile" target=192.168.1.34/32
/queue tree
add disabled=yes max-limit=60M name="All Bandwith " parent=global priority=1
add max-limit=60M name=Download packet-mark=client-dw-pk parent=
"All Bandwith " priority=2 queue=pcq-download-default
add max-limit=50M name=http-dw packet-mark=http-dw-pk parent=Download
priority=1 queue=pcq-download-default
add max-limit=60M name=other-dw packet-mark=other-dw-pk parent=Download
add max-limit=60M name=Upload parent="All Bandwith " queue=pcq-upload-default
add max-limit=50M name=http-up packet-mark=http-up-pk parent=Upload priority=
1 queue=pcq-upload-default
add max-limit=50M name=other-up packet-mark=other-up-pk parent=Upload
priority=2 queue=pcq-upload-default
add bridge=bridge1-LAN interface=ether2-LAN
/ip settings
set accept-redirects=yes accept-source-route=yes tcp-syncookies=yes
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set allow-fast-path=yes authentication=mschap1,mschap2 default-profile=
"l2tp vpn" enabled=yes use-ipsec=yes
add interface=WAN1 list=WAN
add list=LAN
add interface=bridge1-LAN list=LAN
/interface ovpn-server server
set auth=sha1 certificate=server cipher=aes256 require-client-certificate=yes
/interface pptp-server server
set default-profile=default
/interface sstp-server server
set default-profile=default-encryption
/ip accounting
set account-local-traffic=yes enabled=yes
/ip accounting web-access
set accessible-via-web=yes address=192.168.1.68/32
add address=103.105.208.226/29 comment="ISP Connectel" interface=WAN1
network=103.105.208.224
add address=192.168.1.10/24 comment=LAN interface=bridge1-LAN network=
192.168.1.0
add address=103.105.208.226/29 comment="ISP Connectel Backup" interface=WAN3
add address=122.129.78.160/24 comment="WAN 3 Brain" interface=WAN2 network=
122.129.78.0
add address=122.129.78.160/24 comment=" Brain Backup" interface=WAN4 network=
122.129.78.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add interface=WAN1
/ip dhcp-server lease
add address=192.168.1.44 comment="Docker Virtual Machine" mac-address=
00:15:5D:01:44:00 server=dhcp1
add address=192.168.1.108 client-id=1:90:9a:4a:3f:27:4d comment=
"TPlink router" mac-address=90:9A:4A:3F:27:4D server=dhcp1
add address=192.168.1.22 client-id=1:f8:d0:27:59:61:9e comment=
"Epson Printer" mac-address=F8:D0:27:59:61:9E server=dhcp1
add address=192.168.1.28 client-id=1:50:d4:f7:3c:79:f9 mac-address=
50:D4:F7:3C:79:F9 server=dhcp1
add address=192.168.1.46 client-id=1:72:5f:99:d0:9b:39 comment=
"Umar SEO Mobile" mac-address=72:5F:99:D0:9B:39 server=dhcp1
add address=192.168.1.48 client-id=1:d6:27:b5:5a:47:9b comment="Zia Iphone"
mac-address=D6:27:B5:5A:47:9B server=dhcp1
add address=192.168.1.11 client-id=1:e8:5a:8b:36:fb:b4 comment=
"Mehroze Mobile" mac-address=E8:5A:8B:36:FB:B4 server=dhcp1
add address=192.168.1.47 client-id=1:c0:a5:dd:21:6a:c7 comment=
"Mercusys Router" mac-address=C0:A5:DD:21:6A:C7 server=dhcp1
add address=192.168.1.57 client-id=1:90:1b:e:36:4c:f5 mac-address=
90:1B:0E:36:4C:F5 server=dhcp1
add address=192.168.1.24 client-id=1:ee:ef:18:88:8c:15 mac-address=
EE:EF:18:88:8C:15 server=dhcp1
add address=192.168.1.18 client-id=1:0:e0:4c:36:c:fe comment="Hamza MacBook"
mac-address=00:E0:4C:36:0C:FE server=dhcp1
add address=192.168.1.20 client-id=1:5e:e7:10:c0:f1:8d comment=
"Umar SEO Mobile" mac-address=5E:E7:10:C0:F1:8D server=dhcp1
add address=192.168.1.31 client-id=1:14:d1:69:8b:0:aa comment="Hamza Mobile"
mac-address=14:D1:69:8B:00:AA server=dhcp1
add address=192.168.1.23 client-id=1:7c:2a:db:ed:70:d9 comment="Noman Mobile"
mac-address=7C:2A:DB:ED:70:D9 server=dhcp1
add address=192.168.1.16 client-id=1:ca:fc:ef:d7:b3:0 mac-address=
CA:FC:EF:D7:B3:00 server=dhcp1
add address=192.168.1.17 client-id=1:b0:eb:57:f9:1c:83 comment="Sania Mobile"
mac-address=B0:EB:57:F9:1C:83 server=dhcp1
add address=192.168.1.35 client-id=1:a4:7:b6:d:fa:61 comment="Nosheen Mobile"
mac-address=A4:07:B6:0D:FA:61 server=dhcp1
add address=192.168.1.36 client-id=1:9e:51:1b:d1:7a:34 comment=
"Ayesha Mobile" mac-address=9E:51:1B:D1:7A:34 server=dhcp1
add address=192.168.1.37 client-id=1:ac:7:5f:b8:31:56 comment="Sehar Mobile"
mac-address=AC:07:5F:B8:31:56 server=dhcp1
add address=192.168.1.38 client-id=1:52:ec:b5:53:b2:fe comment="Hafsa Mobile"
mac-address=52:EC:B5:53:B2:FE server=dhcp1
add address=192.168.1.19 client-id=1:60:f8:1d:c8:92:12 mac-address=
60:F8:1D:C8:92:12 server=dhcp1
add address=192.168.1.41 client-id=1:50:3e:aa:8e:26:9d mac-address=
50:3E:AA:8E:26:9D server=dhcp1
add address=192.168.1.27 client-id=1:20:26:81:a8:e5:c1 mac-address=
20:26:81:A8:E5:C1 server=dhcp1
add address=192.168.1.103 comment="Bilal Mobile" mac-address=
94:FE:22:B3:9C:9C server=dhcp1
add address=192.168.1.14 client-id=1:a4:1f:72:88:77:b6 mac-address=
A4:1F:72:88:77:B6 server=dhcp1
add address=192.168.1.13 client-id=1:b8:ca:3a:8f:8d:2f mac-address=
B8:CA:3A:8F:8D:2F server=dhcp1
add address=192.168.1.53 client-id=1:5c:f9:dd:6e:f6:48 mac-address=
5C:F9:DD:6E:F6:48 server=dhcp1
add address=192.168.1.30 client-id=1:c8:1f:66:e:8b:8a mac-address=
C8:1F:66:0E:8B:8A server=dhcp1
add address=192.168.1.42 client-id=1:dc:a2:66:7b:e8:d3 mac-address=
DC:A2:66:7B:E8:D3 server=dhcp1
add address=192.168.1.40 comment="Burhan Sami Mobile" mac-address=
44:04:44:80:4C:21 server=dhcp1
add address=192.168.1.106 client-id=1:d0:67:e5:e9:9f:c0 comment=DC02
mac-address=D0:67:E5:E9:9F:C0 server=dhcp1
add address=192.168.1.68 client-id=1:ec:f4:bb:bf:91:f8 comment=DC01
mac-address=EC:F4:BB:BF:91:F8 server=dhcp1
add address=192.168.1.109 client-id=1:0:17:61:12:85:a6 mac-address=
00:17:61:12:85:A6 server=dhcp1
add address=192.168.1.121 client-id=1:e6:76:39:2f:d6:83 comment=
"Imtiaz Mobile" mac-address=E6:76:39:2F:D6:83 server=dhcp1
add address=192.168.1.72 client-id=1:64:0:6a:72:2:2f comment="Burhan PC"
mac-address=64:00:6A:72:02:2F server=dhcp1
add address=192.168.1.80 client-id=1:20:da:22:89:fc:9f mac-address=
20:DA:22:89:FC:9F server=dhcp1
add address=192.168.1.55 client-id=1:8:0:27:ab:51:72 comment=
"Dude Server For Network Monitring " mac-address=08:00:27:AB:51:72
server=dhcp1
add address=192.168.1.63 client-id=1:9c:14:63:20:6c:49 comment="Dahuwa XVR"
mac-address=9C:14:63:20:6C:49 server=dhcp1
add address=192.168.1.34 client-id=1:2c:78:e:79:15:f9 comment="kainat Mobile"
mac-address=2C:78:0E:79:15:F9 server=dhcp1
add address=103.105.208.224/29 comment=WAN1-connectel gateway=103.105.208.225
add address=192.168.1.0/24 comment=LAN1 gateway=192.168.1.10 netmask=24
set allow-remote-requests=yes servers=192.168.1.68,8.8.8.8,192.168.1.106
/ip firewall address-list
add address=192.168.1.110 list="Block users "
add address=192.168.1.73 list="Block users "
add address=192.168.1.48 comment="Col Iphone" list="Active Wifi Client"
add address=192.168.1.125 comment="Fahad Mobile" list="Active Wifi Client"
add address=192.168.1.22 comment="Sania Mobile" list="Active Wifi Client"
add address=192.168.1.28 comment="Sehar Mobile" list="Active Wifi Client"
add address=192.168.1.72 comment="Burhan Sami Mobile" list=
add address=192.168.1.51 list="Active Wifi Client"
add address=192.168.1.76 comment="Burhan Sami Mobile" list=
add address=192.168.1.77 list="Active Wifi Client"
add address=192.168.1.0/25 comment="PBR Load Balncing List" list=GroupA
add address=192.168.1.128/25 list=GroupB
add address=192.168.0.0/24 list=Local
add address=192.168.1.46 comment="Umar SEO Mobile" list="Active Wifi Client"
add address=192.168.1.35 comment="Nosheen Mobile" list="Active Wifi Client"
add address=192.168.1.36 comment="Ayesha Mobile" list="Active Wifi Client"
add address=192.168.1.38 comment="Hafsa Mobile" list="Active Wifi Client"
add address=192.168.1.11 comment="Mehroze Mobile" list="Active Wifi Client"
add address=192.168.1.20 comment="Umar SEO mobile" list="Active Wifi Client"
add address=192.168.1.17 comment="Sania Mobile" list="Active Wifi Client"
add address=192.168.1.31 comment="Hamza Mobile" list="Active Wifi Client"
add address=192.168.2.0 list="l2tp Vpn"
add address=192.168.1.52 comment="Fahad Mobile" list="Active Wifi Client"
add address=192.168.1.103 comment="Bilal Mobile" list="Active Wifi Client"
add address=192.168.1.49 comment="Zias Iphone" list="Active Wifi Client"
add address=192.168.1.40 comment="burhan sami mobile" list=
add address=192.168.1.121 comment="Imtiaz Mobile" list="Active Wifi Client"
add address=192.168.1.80 comment="Rizwan Mobile" list="Active Wifi Client"
add address=157.240.218.17 list="Facebook_Address List"
add address=103.105.208.226 list="Facebook_Address List"
add address=103.105.208.226 list="Youtube_Address List"
add address=157.240.218.35 list="Facebook_Address List"
add address=157.240.27.35 list="Facebook_Address List"
add address=157.240.27.18 list="Facebook_Address List"
add address=216.58.207.14 list="Youtube_Address List"
add address=157.240.235.34 list="Facebook_Address List"
add address=157.240.15.35 list="Facebook_Address List"
add address=157.240.235.36 list="Facebook_Address List"
add address=157.240.235.16 list="Facebook_Address List"
add address=157.240.15.1 list="Facebook_Address List"
add address=157.240.15.19 list="Facebook_Address List"
add address=122.129.78.160 list="Youtube_Address List"
add address=103.111.33.126 list="Facebook_Address List"
add address=196.53.110.134 list="Facebook_Address List"
add address=196.53.110.110 list="Facebook_Address List"
add address=122.129.78.160 list="Facebook_Address List"
add address=157.240.227.34 list="Facebook_Address List"
add address=157.240.227.19 list="Facebook_Address List"
add address=157.240.218.37 list="Facebook_Address List"
add address=157.240.15.34 list="Facebook_Address List"
add address=157.240.218.10 list="Facebook_Address List"
add address=157.240.227.1 list="Facebook_Address List"
add address=157.240.227.35 list="Facebook_Address List"
add address=142.250.181.78 list="Youtube_Address List"
add address=157.240.27.11 list="Facebook_Address List"
add address=157.240.227.13 list="Facebook_Address List"
add address=103.111.33.123 list="Facebook_Address List"
add address=103.111.33.105 list="Facebook_Address List"
add address=185.60.216.19 list="Facebook_Address List"
add address=157.240.10.10 list="Facebook_Address List"
add address=157.240.10.35 list="Facebook_Address List"
add address=142.250.181.37 list="Gmail_Address List"
add address=157.240.218.34 list="Facebook_Address List"
add address=157.240.27.34 list="Facebook_Address List"
add address=157.240.10.18 list="Facebook_Address List"
add address=157.240.218.15 list="Facebook_Address List"
add address=142.250.13.138 list="Youtube_Address List"
add address=142.250.110.139 list="Youtube_Address List"
add address=108.177.15.198 list="Youtube_Address List"
add address=157.240.218.24 list="Facebook_Address List"
add address=142.250.181.14 list="Youtube_Address List"
add address=142.250.110.100 list="Youtube_Address List"
add address=157.240.7.20 list="Facebook_Address List"
add address=157.240.227.17 list="Facebook_Address List"
add address=142.250.110.138 list="Youtube_Address List"
add address=172.217.19.174 list="Youtube_Address List"
add address=142.250.110.113 list="Youtube_Address List"
add address=142.250.110.101 list="Youtube_Address List"
add address=122.129.78.160 list="Gmail_Address List"
add address=142.250.110.102 list="Youtube_Address List"
add address=157.240.227.36 list="Facebook_Address List"
add address=185.61.154.214 list="Facebook_Address List"
add address=142.250.13.113 list="Youtube_Address List"
add address=157.240.235.35 list="Facebook_Address List"
add address=216.58.208.238 list="Youtube_Address List"
add address=157.240.15.17 list="Facebook_Address List"
add address=172.217.21.46 list="Youtube_Address List"
add address=142.250.181.46 list="Youtube_Address List"
add address=157.240.195.36 list="Facebook_Address List"
add address=185.151.30.177 list="Facebook_Address List"
add address=198.23.60.210 list="Facebook_Address List"
add address=45.84.205.242 list="Facebook_Address List"
add address=142.250.181.110 list="Youtube_Address List"
add address=172.217.19.14 list="Youtube_Address List"
add address=172.253.120.100 list="Youtube_Address List"
add address=31.13.82.34 list="Facebook_Address List"
add address=31.13.82.1 list="Facebook_Address List"
add address=142.250.13.101 list="Youtube_Address List"
add address=157.240.10.13 list="Facebook_Address List"
add address=157.240.13.35 list="Facebook_Address List"
add address=179.60.194.20 list="Facebook_Address List"
add address=157.240.235.15 list="Facebook_Address List"
add address=142.250.13.139 list="Youtube_Address List"
add address=157.240.218.6 list="Facebook_Address List"
add address=142.250.13.102 list="Youtube_Address List"
add address=74.125.206.100 list="Youtube_Address List"
add address=157.240.20.35 list="Facebook_Address List"
add address=172.217.19.5 list="Gmail_Address List"
add address=157.240.13.32 list="Facebook_Address List"
add address=157.240.13.10 list="Facebook_Address List"
add address=166.62.6.79 list="Gmail_Address List"
add address=104.26.10.159 list="Facebook_Address List"
add address=172.67.222.229 list="Facebook_Address List"
add address=179.60.194.13 list="Facebook_Address List"
add address=157.240.10.23 list="Facebook_Address List"
add address=157.240.235.18 list="Facebook_Address List"
add address=157.240.217.17 list="Facebook_Address List"
add address=157.240.217.15 list="Facebook_Address List"
add address=151.106.121.148 list="Gmail_Address List"
add address=142.250.181.142 list="Youtube_Address List"
add address=152.89.162.194 list="Facebook_Address List"
add address=103.105.208.226 list="Gmail_Address List"
add address=199.87.208.143 list="Facebook_Address List"
add address=199.87.208.109 list="Facebook_Address List"
add address=152.89.162.178 list="Facebook_Address List"
add address=157.240.7.32 list="Facebook_Address List"
add address=179.60.194.32 list="Facebook_Address List"
add address=69.171.250.15 list="Facebook_Address List"
add address=13.35.20.40 list="Youtube_Address List"
add address=104.26.12.187 list="Facebook_Address List"
add address=179.60.194.35 list="Facebook_Address List"
add address=103.111.33.10 list="Facebook_Address List"
add address=157.240.7.13 list="Facebook_Address List"
add address=157.240.7.35 list="Facebook_Address List"
add address=157.240.27.13 list="Facebook_Address List"
add address=31.13.86.36 list="Facebook_Address List"
add address=157.240.15.36 list="Facebook_Address List"
add address=157.240.196.17 list="Facebook_Address List"
add address=157.240.195.17 list="Facebook_Address List"
add address=157.240.217.35 list="Facebook_Address List"
add address=31.13.68.1 list="Facebook_Address List"
add address=31.13.68.13 list="Facebook_Address List"
add address=157.240.15.13 list="Facebook_Address List"
add address=157.240.235.1 list="Facebook_Address List"
add address=142.250.185.238 list="Youtube_Address List"
add address=37.187.152.183 list="Facebook_Address List"
add address=192.142.128.103 list="Facebook_Address List"
add address=107.158.144.30 list="Facebook_Address List"
add address=192.142.128.112 list="Facebook_Address List"
add address=162.255.45.109 list="Facebook_Address List"
add address=172.217.168.78 list="Youtube_Address List"
add address=157.240.27.54 list="Whatsapp Web_Address List"
add address=157.240.195.10 list="Facebook_Address List"
add address=157.240.195.24 list="Facebook_Address List"
add address=47.89.88.76 list="Facebook_Address List"
add address=157.240.7.54 list="Whatsapp Web_Address List"
add address=157.240.7.16 list="Facebook_Address List"
add address=142.250.13.100 list="Youtube_Address List"
add address=157.240.7.36 list="Facebook_Address List"
add address=103.111.33.122 list="Facebook_Address List"
add address=196.53.110.106 list="Facebook_Address List"
add address=103.20.215.198 list="Facebook_Address List"
add address=157.240.10.32 list="Facebook_Address List"
add address=172.253.120.109 list="Gmail_Address List"
add address=196.53.110.13 list="Facebook_Address List"
add address=196.53.110.109 list="Facebook_Address List"
add address=179.60.194.27 list="Facebook_Address List"
add address=157.240.7.26 list="Facebook_Address List"
add address=173.194.76.109 list="Gmail_Address List"
add address=18.67.111.54 list="Youtube_Address List"
add address=74.125.140.108 list="Gmail_Address List"
add address=66.29.137.52 list="Facebook_Address List"
add address=31.13.64.16 list="Facebook_Address List"
add address=69.171.250.13 list="Facebook_Address List"
add address=64.233.167.108 list="Gmail_Address List"
add address=64.233.184.109 list="Gmail_Address List"
add address=47.254.56.66 list="Gmail_Address List"
add address=74.125.133.108 list="Gmail_Address List"
add address=157.240.196.35 list="Facebook_Address List"
add address=122.129.78.160 list="Whatsapp Web_Address List"
add address=128.52.130.229 list="Gmail_Address List"
add address=66.102.1.109 list="Gmail_Address List"
add address=172.253.120.113 list="Youtube_Address List"
add address=104.21.54.28 list="Facebook_Address List"
add address=23.185.0.3 list="Facebook_Address List"
add address=66.29.146.20 list="Facebook_Address List"
add address=69.171.250.37 list="Facebook_Address List"
add address=172.253.120.139 list="Youtube_Address List"
add address=64.233.166.108 list="Gmail_Address List"
add address=31.13.86.34 list="Facebook_Address List"
add address=74.125.133.109 list="Gmail_Address List"
add address=157.240.13.9 list="Facebook_Address List"
add address=108.177.15.108 list="Gmail_Address List"
add address=64.233.166.102 list="Youtube_Address List"
add address=31.13.86.2 list="Facebook_Address List"
add address=64.233.184.108 list="Gmail_Address List"
add address=172.253.120.138 list="Youtube_Address List"
add address=23.8.183.78 list="Facebook_Address List"
add address=172.253.120.102 list="Youtube_Address List"
add address=157.240.217.37 list="Facebook_Address List"
add address=216.58.207.110 list="Youtube_Address List"
add address=142.251.5.108 list="Gmail_Address List"
add address=13.35.20.36 list="Youtube_Address List"
add address=216.58.215.238 list="Youtube_Address List"
add address=66.102.1.108 list="Gmail_Address List"
add address=192.124.249.69 list="Facebook_Address List"
add address=142.250.203.110 list="Youtube_Address List"
add address=157.240.217.34 list="Facebook_Address List"
add address=172.217.18.110 list="Youtube_Address List"
add address=23.111.168.43 list="Gmail_Address List"
add address=23.227.38.74 list="Facebook_Address List"
add address=157.240.13.14 list="Facebook_Address List"
add address=74.125.140.109 list="Gmail_Address List"
add address=157.90.71.225 list="Facebook_Address List"
add address=157.240.218.33 list="Facebook_Address List"
add address=142.251.5.100 list="Youtube_Address List"
add address=142.251.5.113 list="Youtube_Address List"
add address=142.251.5.101 list="Youtube_Address List"
add address=142.251.5.198 list="Youtube_Address List"
add address=74.125.140.101 list="Youtube_Address List"
add address=157.240.227.60 list="Whatsapp Web_Address List"
add address=103.111.33.185 list="Facebook_Address List"
add address=104.243.212.115 list="Facebook_Address List"
add address=173.249.16.241 list="Facebook_Address List"
add address=116.206.231.91 list="Facebook_Address List"
add address=103.231.88.35 list="Facebook_Address List"
add address=79.98.182.103 list="Facebook_Address List"
add address=185.205.204.110 list="Facebook_Address List"
add address=45.9.249.228 list="Facebook_Address List"
add address=185.205.204.103 list="Facebook_Address List"
add address=173.194.76.108 list="Gmail_Address List"
add address=108.158.251.21 list="Youtube_Address List"
add address=172.67.183.178 list="Facebook_Address List"
add address=74.125.140.139 list="Youtube_Address List"
add address=116.206.231.92 list="Facebook_Address List"
add address=74.125.140.138 list="Youtube_Address List"
add address=64.233.167.109 list="Gmail_Address List"
add address=74.125.206.109 list="Gmail_Address List"
add address=74.125.140.113 list="Youtube_Address List"
add address=74.125.140.100 list="Youtube_Address List"
add address=74.125.140.102 list="Youtube_Address List"
add address=104.22.70.203 list="Facebook_Address List"
add address=157.240.13.19 list="Facebook_Address List"
add address=142.250.110.108 list="Gmail_Address List"
add address=172.253.120.198 list="Youtube_Address List"
add address=66.102.1.198 list="Youtube_Address List"
add address=108.177.15.138 list="Youtube_Address List"
add address=108.177.15.102 list="Youtube_Address List"
add address=108.177.15.113 list="Youtube_Address List"
add address=108.177.15.101 list="Youtube_Address List"
add address=108.177.15.139 list="Youtube_Address List"
add address=108.177.15.100 list="Youtube_Address List"
add address=173.194.76.100 list="Youtube_Address List"
add address=173.194.76.101 list="Youtube_Address List"
add address=173.194.76.102 list="Youtube_Address List"
add address=31.13.66.34 list="Facebook_Address List"
add address=173.194.76.138 list="Youtube_Address List"
add address=173.194.76.139 list="Youtube_Address List"
add address=173.194.76.113 list="Youtube_Address List"
add address=192.81.209.89 list="Youtube_Address List"
add address=198.187.29.102 list="Facebook_Address List"
add address=192.99.220.43 list="Facebook_Address List"
add address=185.60.216.32 list="Facebook_Address List"
add address=74.125.133.102 list="Youtube_Address List"
add address=157.240.195.35 list="Facebook_Address List"
add address=74.125.133.100 list="Youtube_Address List"
add address=157.240.195.56 list="Whatsapp Web_Address List"
add address=142.250.110.198 list="Youtube_Address List"
add address=157.240.195.34 list="Facebook_Address List"
add address=74.125.133.113 list="Youtube_Address List"
add address=185.205.204.102 list="Facebook_Address List"
add address=13.35.13.68 list="Youtube_Address List"
add address=64.233.166.109 list="Gmail_Address List"
add address=185.60.216.35 list="Facebook_Address List"
add address=31.13.84.8 list="Facebook_Address List"
add address=157.240.7.38 list="Facebook_Address List"
add address=31.13.84.36 list="Facebook_Address List"
add address=31.13.84.34 list="Facebook_Address List"
add address=185.60.216.15 list="Facebook_Address List"
add address=157.240.227.33 list="Facebook_Address List"
add address=103.105.210.2 list="Gmail_Address List"
add address=157.240.227.2 list="Facebook_Address List"
add address=103.111.33.12 list="Facebook_Address List"
add address=31.13.70.36 list="Facebook_Address List"
add address=172.67.207.14 list="Facebook_Address List"
add address=45.84.204.237 list="Gmail_Address List"
add address=157.240.19.35 list="Facebook_Address List"
add address=157.240.14.35 list="Facebook_Address List"
add address=31.13.67.16 list="Facebook_Address List"
add address=157.240.3.15 list="Facebook_Address List"
add address=142.250.13.198 list="Youtube_Address List"
add address=31.13.84.2 list="Facebook_Address List"
add address=104.122.9.200 list="Facebook_Address List"
add address=172.67.218.48 list="Facebook_Address List"
add address=157.240.220.35 list="Facebook_Address List"
add address=67.21.32.232 list="Facebook_Address List"
add address=185.205.204.100 list="Facebook_Address List"
add address=185.205.204.106 list="Facebook_Address List"
add address=50.3.224.10 list="Facebook_Address List"
add address=199.87.208.125 list="Facebook_Address List"
add address=54.93.38.117 list="Facebook_Address List"
add address=23.22.202.126 list="Facebook_Address List"
add address=173.194.76.198 list="Youtube_Address List"
add address=103.108.92.188 list="Facebook_Address List"
add address=185.209.178.49 list="Facebook_Address List"
add address=67.199.248.10 list="Youtube_Address List"
add address=208.91.198.74 list="Youtube_Address List"
add address=208.91.198.74 list="Gmail_Address List"
add address=50.3.188.34 list="Facebook_Address List"
add address=216.58.207.101 list="Gmail_Address List"
add address=67.219.150.108 list="Facebook_Address List"
add address=157.240.2.35 list="Facebook_Address List"
add address=142.250.190.46 list="Youtube_Address List"
add address=142.250.190.14 list="Youtube_Address List"
add address=142.250.190.110 list="Youtube_Address List"
add address=142.250.191.206 list="Youtube_Address List"
add address=172.217.4.46 list="Youtube_Address List"
add address=13.35.13.113 list="Youtube_Address List"
add address=156.67.73.48 list="Facebook_Address List"
add address=198.37.116.43 list="Facebook_Address List"
add address=103.83.81.68 list="Facebook_Address List"
add address=40.91.127.220 list="Gmail_Address List"
add address=185.60.216.53 list="Whatsapp Web_Address List"
add address=31.177.76.70 list="Facebook_Address List"
add address=162.218.230.220 list="Facebook_Address List"
add address=162.218.230.219 list="Facebook_Address List"
add address=162.218.230.221 list="Facebook_Address List"
add address=157.240.20.32 list="Facebook_Address List"
add address=207.180.198.156 list="Facebook_Address List"
add address=74.125.71.198 list="Youtube_Address List"
add address=142.250.191.142 list="Youtube_Address List"
add address=157.240.199.35 list="Facebook_Address List"
add address=31.13.84.23 list="Facebook_Address List"
add address=172.217.5.14 list="Youtube_Address List"
add address=142.250.191.110 list="Youtube_Address List"
add address=142.250.72.238 list="Youtube_Address List"
add address=142.250.68.78 list="Youtube_Address List"
add address=172.217.11.174 list="Youtube_Address List"
add address=31.13.92.52 list="Whatsapp Web_Address List"
add address=186.233.185.203 list="Facebook_Address List"
add address=31.13.77.35 list="Facebook_Address List"
add address=31.13.77.17 list="Facebook_Address List"
add address=157.240.199.11 list="Facebook_Address List"
add address=38.99.247.221 list="Facebook_Address List"
add address=38.99.247.219 list="Facebook_Address List"
add address=142.250.180.46 list="Youtube_Address List"
add address=185.60.216.10 list="Facebook_Address List"
add address=216.58.208.78 list="Youtube_Address List"
add address=142.250.180.37 list="Gmail_Address List"
add address=142.250.72.110 list="Youtube_Address List"
add address=66.115.182.34 list="Facebook_Address List"
add address=31.13.84.51 list="Whatsapp Web_Address List"
add address=157.240.20.15 list="Facebook_Address List"
add address=31.13.92.10 list="Facebook_Address List"
add address=157.240.20.52 list="Whatsapp Web_Address List"
add address=216.58.209.142 list="Youtube_Address List"
add address=196.53.110.111 list="Facebook_Address List"
add address=35.213.179.33 list="Facebook_Address List"
add address=142.250.185.46 list="Youtube_Address List"
add address=44.236.54.143 list="Facebook_Address List"
add address=66.154.110.180 list="Facebook_Address List"
add address=172.217.18.142 list="Youtube_Address List"
add address=13.35.175.26 list="Youtube_Address List"
add address=13.35.175.13 list="Youtube_Address List"
add address=50.3.224.11 list="Facebook_Address List"
add address=104.18.254.23 list="Facebook_Address List"
add address=207.188.7.130 list="Facebook_Address List"
add address=157.240.18.35 list="Facebook_Address List"
add address=157.240.199.17 list="Facebook_Address List"
add address=198.54.128.22 list="Facebook_Address List"
add address=157.240.22.35 list="Facebook_Address List"
add address=162.218.230.196 list="Facebook_Address List"
add address=108.177.15.109 list="Gmail_Address List"
add address=198.134.107.195 list="Facebook_Address List"
add address=15.197.142.173 list="Facebook_Address List"
add address=162.255.45.117 list="Facebook_Address List"
add address=204.27.63.179 list="Facebook_Address List"
add address=3.33.152.147 list="Facebook_Address List"
add address=166.62.26.2 list="Gmail_Address List"
add address=82.102.31.83 list="Facebook_Address List"
add address=103.105.208.226 list="Whatsapp Web_Address List"
add address=142.250.68.46 list="Youtube_Address List"
add address=142.250.188.238 list="Youtube_Address List"
add address=157.240.11.35 list="Facebook_Address List"
add address=142.250.68.14 list="Youtube_Address List"
add address=162.255.46.154 list="Facebook_Address List"
add address=104.243.213.102 list="Facebook_Address List"
add address=157.240.241.34 list="Facebook_Address List"
add address=31.13.71.34 list="Facebook_Address List"
add address=31.13.71.36 list="Facebook_Address List"
add address=194.163.142.38 list="Facebook_Address List"
add address=151.101.2.159 list="Gmail_Address List"
add address=31.13.71.1 list="Facebook_Address List"
add address=68.235.48.20 list="Facebook_Address List"
add address=64.233.184.138 list="Youtube_Address List"
add address=216.58.210.78 list="Youtube_Address List"
add address=173.44.34.5 list="Facebook_Address List"
add address=157.240.241.35 list="Facebook_Address List"
add address=162.215.249.107 list="Facebook_Address List"
add address=157.240.14.32 list="Facebook_Address List"
add address=192.142.128.117 list="Facebook_Address List"
add address=107.158.144.58 list="Facebook_Address List"
add address=104.193.240.131 list="Facebook_Address List"
add address=64.233.166.198 list="Youtube_Address List"
add address=157.240.196.34 list="Facebook_Address List"
add address=196.53.110.128 list="Facebook_Address List"
add address=185.209.178.10 list="Facebook_Address List"
add address=66.102.1.102 list="Youtube_Address List"
add address=108.177.125.102 list="Youtube_Address List"
add address=66.102.1.138 list="Youtube_Address List"
add address=66.102.1.113 list="Youtube_Address List"
add address=66.102.1.101 list="Youtube_Address List"
add address=66.102.1.139 list="Youtube_Address List"
add address=108.177.125.101 list="Youtube_Address List"
add address=3.223.115.185 list="Facebook_Address List"
add address=198.54.125.199 list="Facebook_Address List"
add address=143.204.109.87 list="Youtube_Address List"
add address=66.102.1.100 list="Youtube_Address List"
add address=162.218.230.195 list="Facebook_Address List"
add address=208.96.18.238 list="Gmail_Address List"
add address=142.250.190.78 list="Youtube_Address List"
add address=142.251.5.109 list="Gmail_Address List"
add address=157.240.3.35 list="Facebook_Address List"
add address=172.67.204.149 list="Facebook_Address List"
add address=172.253.120.108 list="Gmail_Address List"
add address=157.240.18.9 list="Facebook_Address List"
add address=104.21.48.45 list="Facebook_Address List"
add address=104.21.93.48 list="Facebook_Address List"
add address=184.154.83.101 list="Facebook_Address List"
add address=172.217.21.37 list="Gmail_Address List"
add address=119.160.98.79 list="Gmail_Address List"
add address=45.58.41.170 list="Gmail_Address List"
add address=143.204.109.31 list="Youtube_Address List"
add address=157.240.26.35 list="Facebook_Address List"
add address=74.125.133.198 list="Youtube_Address List"
add address=31.13.65.36 list="Facebook_Address List"
add address=157.240.18.15 list="Facebook_Address List"
add address=64.233.184.101 list="Youtube_Address List"
add address=64.233.184.139 list="Youtube_Address List"
add address=31.13.70.1 list="Facebook_Address List"
add address=104.21.34.124 list="Facebook_Address List"
add address=172.67.205.4 list="Facebook_Address List"
add address=103.231.88.36 list="Facebook_Address List"
add address=43.245.160.5 list="Facebook_Address List"
add address=192.142.128.113 list="Facebook_Address List"
add address=103.111.33.181 list="Facebook_Address List"
add address=198.143.164.254 list="Facebook_Address List"
add address=216.18.194.210 list="Facebook_Address List"
add address=172.67.203.252 list="Facebook_Address List"
add address=216.239.38.21 list="Facebook_Address List"
add address=142.250.181.19 list="Facebook_Address List"
add address=104.21.42.178 list="Facebook_Address List"
add address=64.233.167.101 list="Youtube_Address List"
add address=166.62.112.193 list="Facebook_Address List"
add address=198.143.164.254 list="Youtube_Address List"
add address=159.89.244.183 list="Youtube_Address List"
add address=185.201.11.10 list="Facebook_Address List"
add address=216.58.208.84 list="Facebook_Address List"
add address=185.214.127.158 list="Facebook_Address List"
add address=64.233.184.198 list="Youtube_Address List"
add address=31.13.67.35 list="Facebook_Address List"
add address=31.13.66.35 list="Facebook_Address List"
add address=179.60.192.2 list="Facebook_Address List"
add address=185.60.216.36 list="Facebook_Address List"
add address=142.250.114.91 list="Youtube_Address List"
add address=142.251.32.238 list="Youtube_Address List"
add address=142.251.32.174 list="Youtube_Address List"
add address=51.195.104.87 list="Facebook_Address List"
add address=159.65.72.135 list="Gmail_Address List"
add address=31.13.71.49 list="Whatsapp Web_Address List"
add address=185.60.216.11 list="Facebook_Address List"
add address=157.240.218.60 list="Whatsapp Web_Address List"
add address=204.14.73.171 list="Facebook_Address List"
add address=142.250.27.109 list="Gmail_Address List"
add address=142.250.102.109 list="Gmail_Address List"
add address=172.217.169.238 list="Youtube_Address List"
add address=156.67.222.95 list="Facebook_Address List"
add address=142.250.102.108 list="Gmail_Address List"
add address=143.204.46.73 list="Youtube_Address List"
add address=142.250.27.108 list="Gmail_Address List"
add address=160.153.131.150 list="Facebook_Address List"
add address=172.67.180.53 list="Facebook_Address List"
add address=31.170.160.33 list="Facebook_Address List"
add address=128.2.44.120 list="Gmail_Address List"
add address=172.67.177.248 list="Gmail_Address List"
add address=157.240.229.17 list="Facebook_Address List"
add address=104.21.47.72 list="Facebook_Address List"
add address=155.254.23.180 list="Facebook_Address List"
add address=104.21.77.74 list="Gmail_Address List"
add address=157.240.20.10 list="Facebook_Address List"
add address=31.13.93.53 list="Whatsapp Web_Address List"
add address=42.201.190.197 list="Youtube_Address List"
add address=31.13.86.8 list="Facebook_Address List"
add address=192.142.128.114 list="Facebook_Address List"
add address=196.53.110.129 list="Facebook_Address List"
add address=143.204.109.34 list="Youtube_Address List"
add address=162.0.229.55 list="Facebook_Address List"
add address=157.240.196.60 list="Whatsapp Web_Address List"
add address=50.3.188.36 list="Facebook_Address List"
add address=158.69.225.63 list="Facebook_Address List"
add address=142.250.13.108 list="Gmail_Address List"
add address=157.240.236.35 list="Facebook_Address List"
add address=156.67.73.189 list="Facebook_Address List"
add address=74.125.167.89 list="Youtube_Address List"
add address=74.125.12.72 list="Youtube_Address List"
add address=107.190.135.221 list="Facebook_Address List"
add address=172.217.168.14 list="Youtube_Address List"
add address=204.14.73.131 list="Facebook_Address List"
add address=157.240.20.9 list="Facebook_Address List"
add address=18.66.196.96 list="Youtube_Address List"
add address=172.217.168.46 list="Youtube_Address List"
add address=157.240.18.52 list="Whatsapp Web_Address List"
add address=157.240.2.53 list="Whatsapp Web_Address List"
add address=104.21.90.154 list="Facebook_Address List"
add address=179.60.194.12 list="Facebook_Address List"
add address=157.240.236.15 list="Facebook_Address List"
add address=157.240.28.51 list="Whatsapp Web_Address List"
add address=192.168.1.34 comment="kainat Mobile" list="Active Wifi Client"
add address=157.240.196.10 list="Facebook_Address List"
add address=151.101.2.152 list="Gmail_Address List"
add address=157.240.227.56 list="Facebook_Address List"
add address=111.119.187.11 list="Gmail_Address List"
add address=142.250.13.109 list="Gmail_Address List"
add address=172.217.16.142 list="Youtube_Address List"
add address=142.250.185.206 list="Youtube_Address List"
add address=142.250.186.78 list="Youtube_Address List"
add address=142.250.184.206 list="Youtube_Address List"
add action=drop chain=forward comment="Block Wifi Clients" src-address-list=
"Block users "
add action=drop chain=forward dst-port=
!0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=tcp
src-address-list=Torrent-Conn
!0-1024,8291,5900,5800,3389,14147,5222,59905 protocol=udp
add action=add-src-to-address-list address-list=Torrent-Conn
address-list-timeout=2m chain=forward layer7-protocol=
layer7-bittorrent-exp src-address=192.168.1.0/24 src-address-list=
!allow-bit
add action=add-src-to-address-list address-list="TCPIP Block_List"
address-list-timeout=1d chain=input comment=
"Prevention DDoS Via TCP IP Connection Time out" connection-limit=32,32
protocol=tcp
add action=jump chain=forward comment="SYN Flood Protect FORWARD"
connection-state=new jump-target=syn-attack protocol=tcp tcp-flags=syn
add action=jump chain=input comment="SYN Flood protect INPUT"
add action=accept chain=syn-attack connection-state=new limit=400,5:packet
add action=drop chain=syn-attck connection-state=new protocol=tcp tcp-flags=
syn
add action=drop chain=forward comment="SMB Attack on DC-02" dst-port=445
protocol=tcp src-address=192.168.1.106
add action=add-src-to-address-list address-list="Port Scaning Attack"
address-list-timeout=none-dynamic chain=forward comment=
"Prevention from Port Scaning Attack FORWARD" protocol=tcp psd=21,3s,3,1
add action=add-src-to-address-list address-list="Port Scaning Attack UDP"
"Prevention from Port Scaning Attack FORWARD" protocol=udp psd=21,3s,3,1
address-list-timeout=none-dynamic chain=input comment=
"Prevention from Port Scaning Attack INPUT" protocol=tcp psd=21,3s,3,1
"Prevention from Port Scaning Attack INPUT" protocol=udp psd=21,3s,3,1
add action=drop chain=forward protocol=tcp src-address-list=
add action=drop chain=forward protocol=udp src-address-list=
add action=drop chain=input protocol=tcp src-address-list=
add action=drop chain=input protocol=udp src-address-list=
/ip firewall mangle
add action=mark-connection chain=forward comment=client-dw-conn in-interface=
WAN1 new-connection-mark=client-dw-conn passthrough=yes
add action=mark-packet chain=forward comment=client-dw-pk connection-mark=
client-dw-conn new-packet-mark=client-dw-pk passthrough=yes
add action=mark-connection chain=prerouting comment=client-up-conn
in-interface=bridge1-LAN new-connection-mark=client-up-conn passthrough=
yes
add action=mark-packet chain=prerouting comment=client-up-pk connection-mark=
client-up-conn new-packet-mark=client-up-pk passthrough=yes
add action=mark-packet chain=forward comment=http-dw-pk new-packet-mark=
http-dw-pk packet-mark=client-dw-pk passthrough=no port=80,443 protocol=
tcp
add action=mark-packet chain=forward comment=http-up-pk dst-port=80,443
new-packet-mark=http-up-pk packet-mark=client-up-pk passthrough=no
protocol=tcp
add action=mark-packet chain=forward comment=other-dw-pk new-packet-mark=
other-dw-pk packet-mark=client-dw-pk passthrough=no
add action=mark-packet chain=forward comment=other-up-pk new-packet-mark=
other-up-pk packet-mark=client-up-pk passthrough=no
add action=change-ttl chain=postrouting comment="Change TTL Rule" disabled=
yes new-ttl=set:3 out-interface=bridge1-LAN passthrough=no
add action=mark-routing chain=prerouting comment=
"WAN1 and WAN2 load balancing Rule" dst-address-list=!Local
new-routing-mark=to_WAN1 passthrough=no src-address-list=GroupA
add action=mark-routing chain=prerouting comment=Brain dst-address-list=
!Local new-routing-mark=to_WAN2 passthrough=no src-address-list=GroupB
add action=dst-nat chain=dstnat comment="SMB 1" dst-port=445 in-interface=
WAN1 protocol=tcp to-addresses=192.168.1.68 to-ports=445
add action=dst-nat chain=dstnat comment="SMB 5" dst-port=445 in-interface=
WAN3 protocol=tcp to-addresses=192.168.1.68 to-ports=445
add action=dst-nat chain=dstnat comment="SMB 4" dst-port=139 in-interface=
WAN1 protocol=tcp to-addresses=192.168.1.68 to-ports=139
WAN3 protocol=tcp to-addresses=192.168.1.68 to-ports=139
add action=dst-nat chain=dstnat comment="output messenger " dst-address=
103.105.208.226 dst-port=14121 in-interface=WAN1 protocol=tcp
to-addresses=192.168.1.106 to-ports=14121
122.129.78.160 dst-port=14121 in-interface=WAN2 protocol=tcp
103.105.208.226 dst-port=14121 in-interface=WAN3 protocol=tcp
add action=dst-nat chain=dstnat comment="RDP DC01" dst-port=3389
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.68 to-ports=3389
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.68 to-ports=3389
in-interface=WAN3 protocol=tcp to-addresses=192.168.1.68 to-ports=3389
add action=dst-nat chain=dstnat comment="RDP DC02" dst-port=3390
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.106 to-ports=3390
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.106 to-ports=3390
in-interface=WAN3 protocol=tcp to-addresses=192.168.1.106 to-ports=3390
add action=dst-nat chain=dstnat comment="Biomatric Machine" dst-address=
103.105.208.226 dst-port=4370 in-interface=WAN1 protocol=tcp
to-addresses=192.168.1.109 to-ports=4370
122.129.78.160 dst-port=4370 in-interface=WAN2 protocol=tcp to-addresses=
103.105.208.226 dst-port=4370 in-interface=WAN3 protocol=tcp
add action=dst-nat chain=dstnat comment=Winbox dst-port=8291 in-interface=
WAN1 protocol=tcp to-addresses=192.168.1.10 to-ports=8291
WAN2 protocol=tcp to-addresses=192.168.1.10 to-ports=8291
WAN3 protocol=tcp to-addresses=192.168.1.10 to-ports=8291
WAN4 protocol=tcp to-addresses=192.168.1.10 to-ports=8291
add action=masquerade chain=srcnat comment="NAT-ISP Connectel" out-interface=
WAN1
add action=masquerade chain=srcnat comment="NAT-ISP Brain" out-interface=WAN2
add action=masquerade chain=srcnat comment="NAT-Backup Connectel"
out-interface=WAN3
add action=masquerade chain=srcnat comment=Brain-Backup out-interface=WAN4
add action=dst-nat chain=dstnat comment=spicework dst-address=103.105.208.226
dst-port=9675 in-interface=WAN1 protocol=tcp to-addresses=192.168.1.106
to-ports=9675
add action=dst-nat chain=dstnat comment=spicework dst-address=122.129.78.160
dst-port=9675 in-interface=WAN2 protocol=tcp to-addresses=192.168.1.106
to-ports=9675
dst-port=9675 in-interface=WAN3 protocol=tcp to-addresses=192.168.1.106
to-ports=9675
add action=dst-nat chain=dstnat comment="Jellyfin Media Server" dst-address=
103.105.208.226 dst-port=8096 in-interface=WAN1 protocol=tcp
to-addresses=192.168.1.68 to-ports=8096
add action=dst-nat chain=dstnat comment="Jellyfin Media Server 2" dst-port=
8096 in-interface=WAN2 protocol=tcp to-addresses=192.168.1.68 to-ports=
8096
dst-address=103.105.208.226 dst-port=8096 in-interface=WAN3 protocol=tcp
add action=dst-nat chain=dstnat comment="EMP Andrew" dst-address=
103.105.208.226 dst-port=4100 in-interface=WAN1 protocol=tcp
to-addresses=192.168.1.250 to-ports=4100
add action=dst-nat chain=dstnat comment="EMP Imtiaz Ahmad" dst-port=4101
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.205 to-ports=4101
add action=dst-nat chain=dstnat comment="EMP Ayesha Saeed" dst-port=4103
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.203 to-ports=4103
add action=dst-nat chain=dstnat comment=" EMP Sania Mustafa " dst-address=
103.105.208.226 dst-port=4104 in-interface=WAN1 protocol=tcp
to-addresses=192.168.1.202 to-ports=4104
add action=dst-nat chain=dstnat comment="EMP Najam ul Sehar" dst-port=4105
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.201 to-ports=4105
add action=dst-nat chain=dstnat comment="EMP Muhammad Sheraz" dst-address=
103.105.208.226 dst-port=4106 in-interface=WAN1 protocol=tcp
to-addresses=192.168.1.206 to-ports=4106
add action=dst-nat chain=dstnat comment="EMP Shahan Sabir" dst-port=4107
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.207 to-ports=4107
add action=dst-nat chain=dstnat comment="EMP Muhammad Ali" dst-port=4108
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.208 to-ports=4108
add action=dst-nat chain=dstnat comment="EMP Burhan Sami" dst-port=4109
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.209 to-ports=4109
add action=dst-nat chain=dstnat comment="EMP Rizwan Jilani" dst-port=4110
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.210 to-ports=4110
add action=dst-nat chain=dstnat comment="EMP Saddam Hussain" dst-port=4111
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.211 to-ports=4111
add action=dst-nat chain=dstnat comment="EMP Haris Rasheed" dst-port=4112
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.212 to-ports=4112
add action=dst-nat chain=dstnat comment="EMP Abdullah Ahmad" dst-port=4113
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.213 to-ports=4113
add action=dst-nat chain=dstnat comment="EMP Umar Shahzad" dst-port=4114
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.214 to-ports=4114
add action=dst-nat chain=dstnat comment="EMP Naveed Iqbal" dst-port=4115
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.215 to-ports=4115
add action=dst-nat chain=dstnat comment="EMP Hafsa Nadeem" dst-port=4116
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.30 to-ports=4116
add action=dst-nat chain=dstnat comment="EMP Hasaan Baig" dst-port=4118
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.74 to-ports=4118
add action=dst-nat chain=dstnat comment="EMP Nosheen Mushtaq" dst-port=4119
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.56 to-ports=4119
add action=dst-nat chain=dstnat comment="EMP Mehroze Shahbaz" dst-port=4120
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.41 to-ports=4120
add action=dst-nat chain=dstnat comment="EMP Fahad Qayyum" dst-port=4122
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.14 to-ports=4122
add action=dst-nat chain=dstnat comment="EMP Hamza Farooq" dst-port=4123
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.59 to-ports=4123
add action=dst-nat chain=dstnat comment="EMP Noman Manzoor" dst-port=4124
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.13 to-ports=4124
add action=dst-nat chain=dstnat comment="EMP Uqba Manzoor" dst-port=4126
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.226 to-ports=4126
add action=dst-nat chain=dstnat comment="EMP Kainat Zawar" dst-port=4127
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.227 to-ports=4127
add action=dst-nat chain=dstnat comment="EMP Tahir Mehmood" dst-port=4128
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.228 to-ports=4128
add action=dst-nat chain=dstnat comment="EMP Tamoor Mir" dst-port=4129
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.229 to-ports=4129
add action=dst-nat chain=dstnat comment="EMP Imran Shoukat" dst-port=4130
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.230 to-ports=4130
add action=dst-nat chain=dstnat comment="EMP Sheeba Nasrullah " dst-port=4133
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.233 to-ports=4133
add action=dst-nat chain=dstnat comment=" EMP Bilal Mazahir" dst-port=4134
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.234 to-ports=4134
add action=dst-nat chain=dstnat comment=" EMP Adam" dst-port=4135
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.53 to-ports=4135
add action=dst-nat chain=dstnat comment=" EMP Aqib" dst-port=4131
in-interface=WAN1 protocol=tcp to-addresses=192.168.1.12 to-ports=4131
add action=dst-nat chain=dstnat comment="EMP Andrew" dst-port=4100
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.250 to-ports=4100
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.205 to-ports=4101
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.203 to-ports=4103
add action=dst-nat chain=dstnat comment=" EMP Sania Mustafa " dst-port=4104
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.202 to-ports=4104
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.201 to-ports=4105
add action=dst-nat chain=dstnat comment="EMP Muhammad Sheraz" dst-port=4106
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.206 to-ports=4106
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.207 to-ports=4107
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.208 to-ports=4108
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.209 to-ports=4109
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.210 to-ports=4110
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.211 to-ports=4111
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.212 to-ports=4112
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.213 to-ports=4113
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.214 to-ports=4114
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.215 to-ports=4115
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.30 to-ports=4116
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.74 to-ports=4118
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.56 to-ports=4119
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.41 to-ports=4120
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.14 to-ports=4122
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.59 to-ports=4123
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.13 to-ports=4124
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.226 to-ports=4126
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.227 to-ports=4127
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.228 to-ports=4128
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.229 to-ports=4129
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.230 to-ports=4130
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.233 to-ports=4133
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.234 to-ports=4134
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.53 to-ports=4135
in-interface=WAN2 protocol=tcp to-addresses=192.168.1.12 to-ports=4131
add action=dst-nat chain=dstnat dst-port=4545 in-interface=WAN1 protocol=tcp
to-addresses=192.168.1.152 to-ports=4545
add action=dst-nat chain=dstnat dst-port=4545 in-interface=WAN2 protocol=tcp
/ip firewall raw
add action=add-dst-to-address-list address-list="Gmail_Address List"
address-list-timeout=none-static chain=prerouting comment=
"Gmail_Address List" content=gmail.com
add action=add-dst-to-address-list address-list="Whatsapp Web_Address List"
"Whatsapp Web_Address List" content=web.whatsapp.com src-address-list=""
add action=add-dst-to-address-list address-list="Facebook_Address List"
"Facebook_Address List" content=facebook.com
add action=add-dst-to-address-list address-list="Youtube_Address List"
"Youtube_Address List" content=youtube.com
add action=drop chain=prerouting comment=
"Prevention UDP 53 DNS amplification Attack" dst-port=53 in-interface=
WAN1 protocol=udp
"Prevention TCP 53 DNS amplification Attack" dst-port=53 in-interface=
WAN1 protocol=tcp
/ip ipsec identity
add peer=L2TP
add check-gateway=ping comment="Connectel Backup" distance=1 gateway=
103.105.208.225 routing-mark=to_WAN1
add check-gateway=ping comment=Brain distance=1 gateway=122.129.78.254
add distance=1 gateway=103.105.208.225%WAN3
103.105.208.225
add check-gateway=ping comment="Brain Backup" distance=1 gateway=
122.129.78.254%WAN4
add check-gateway=ping comment=Brain distance=2 gateway=122.129.78.254
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip traffic-flow
set enabled=yes
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=WAN1 type=external
add interface=ether2-LAN type=internal
add interface=WAN3 type=internal
/ppp secret
add name=l2tp profile="l2tp vpn" service=l2tp
/snmp
set enabled=yes
/system clock
set time-zone-name=Asia/Karachi
/system identity
set name="MikroTik Printing Circle"
/system logging
add topics=dhcp
/system scheduler
add interval=1d name="Mikrotik Config Backup" on-event="/export file=export\r
\n/tool e-mail send to="mujahidshah164@yahoo.com" subject="$[/system i
dentity get name] export" \\r
\nbody=" configuration file $[/system clock get date]" file=export.rsc"
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=aug/26/2021 start-time=10:00:41
/system script
add dont-require-permissions=no name=script1 owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{
\r
\n\t:local listName "Youtube_Address List"; #change this\r
\n\t:local fileName "exported.rsc"; #change this\r
\n\t:local buffer;\r
\n\r
\n\t:global filteredList [/ip firewall address-list print as-value where l
ist=$listName && dynamic=no];\r
\n\t:foreach i in=$filteredList do={\r
\n\t\t:set $buffer ($buffer."add list=".$listName." address=".$i->
"address"."; ");\r
\n\t};\r
\n\t/file print file=$fileName where name="Youtube_Address List";\r
\n\t:delay 1s;\r
\n\t:set $buffer ("/ip firewall address-list; ".$buffer);\r
\n\t/file set $fileName contents=$buffer;"
/tool graphing interface
add store-on-disk=no
/tool graphing queue
add allow-target=no store-on-disk=no
/tool graphing resource
