Cant port forward after Load Balance
Dear All after successfully setup my CRS109 tp Load Balance 4 Wan’s i have found my self in a bump. The thing is that im using 4 ddns services together and i want to port forward a specific internal ip to a specific ddns that is bind in to wan but with no success.
Im using the following configuration.
Any ideas…
4WAN PPPOE LOAD BALANCE
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.15.255 interface=Local
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out1
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out2
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out3
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out4
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=pppoe-out1 new-connection-mark=wan1_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=pppoe-out2 new-connection-mark=wan2_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=pppoe-out3 new-connection-mark=wan3_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=pppoe-out4 new-connection-mark=wan4_conn passthrough=yes
add action=mark-routing chain=output connection-mark=wan1_conn disabled=no new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=output connection-mark=wan2_conn disabled=no new-routing-mark=to_wan2 passthrough=yes
add action=mark-routing chain=output connection-mark=wan3_conn disabled=no new-routing-mark=to_wan3 passthrough=yes
add action=mark-routing chain=output connection-mark=wan4_conn disabled=no new-routing-mark=to_wan4 passthrough=yes
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan1_conn passthrough=yes per-connection-classifier=\ both-addresses-and-ports:4/0
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan2_conn passthrough=yes per-connection-classifier=\ both-addresses-and-ports:4/1
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan3_conn passthrough=yes per-connection-classifier=\ both-addresses-and-ports:4/2
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan4_conn passthrough=yes per-connection-classifier=\ both-addresses-and-ports:4/3
add action=mark-routing chain=prerouting connection-mark=wan1_conn disabled=no in-interface=Local new-routing-mark=to_wan1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wan2_conn disabled=no in-interface=Local new-routing-mark=to_wan2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wan3_conn disabled=no in-interface=Local new-routing-mark=to_wan3 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wan4_conn disabled=no in-interface=Local new-routing-mark=to_wan4 passthrough=yes
add action=accept chain=prerouting disabled=no in-interface=pppoe-out1
add action=accept chain=prerouting disabled=no in-interface=pppoe-out2
add action=accept chain=prerouting disabled=no in-interface=pppoe-out3
add action=accept chain=prerouting disabled=no in-interface=pppoe-out4
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_wan1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_wan2 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out3 routing-mark=to_wan3 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out4 routing-mark=to_wan4 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=3 dst-address=0.0.0.0/0 gateway=pppoe-out3 scope=30 target-scope=10
add check-gateway=ping disabled=no distance=4 dst-address=0.0.0.0/0 gateway=pppoe-out4 scope=30 target-scope=10
set allow-remote-requests=yes cache-max-ttl=1w cache-size=5000KiB max-udp-packet-size=512 servers=8.8.8.8,8.8.4.4
add a mangle rule marking route so that traffic from that IP/port gets route-marked to the desired WAN.
Can you set an example if possible.
Thanks for taking the time to reply.
Let’s suppose you want to port forward 192.168.1.180 port tcp 80 (a web server) through WAN2, you want to make sure responses from the web server always go through WAN2:
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local in-interface=Local new-connection-mark=wan2_conn passthrough=no protocol=tcp src-address=192.168.1.180 src-port=80
Thanks a lot, I will test it tomorrow morning and post back. Thanks again for everything
Seems to be missing something here
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=LOCAL_NETWORK new-connection-mark=WAN_2_conn passthrough=no protocol=tcp src-address=192.168.10.64 src-port=32400
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=LOCAL_NETWORK new-connection-mark=WAN_1_conn per-connection-classifier=both-addresses-and-ports:4/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=LOCAL_NETWORK new-connection-mark=WAN_2_conn per-connection-classifier=both-addresses-and-ports:4/1
add action=dst-nat chain=dstnat dst-port=32400 in-interface=WAN_2 protocol=tcp to-addresses=192.168.10.64 to-ports=32400
What do you mean?
I cant make it work, Am in doing something wrong!!! Mind buster :slight_smile:
Edit:
I have used this one and its working, but i have a 4 seconds delay until it go through. Now im missing the Nat command to make it public via WAN_4
/ ip route
add check-gateway=ping distance=1 dst-address=192.168.10.64/32 gateway=WAN_2 routing-mark=to_WAN_4
/ ip firewall mangle
add action=mark-routing chain=prerouting dst-address=!192.168.0.0/20 new-routing-mark=to_WAN_4 src-address=192.168.10.64
/ ip firewall nat
add action=src-nat chain=srcnat routing-mark=to_WAN_4 to-addresses=192.168.10.64
Why are you setting gateway=WAN2 when route mark is WAN4?
very simple.
add action=accept chain=forward disabled=no dst-address="wan ip" dst-port=80 protocol=tcp
add action=dst-nat chain=dstnat dst-port=1234 in-interface="interface name" protocol=tcp to-addresses="server ip" to-ports=80
That’s because the specified ip address uses wan’s 4 public ip address.
Thanks mate, i will try and report back.
i understand all the code in load balancing script but i cant figure out these lines what are used for and why are needed?
