can't reach the www.google.fr in my MIKROTIK
Hello
I have a mikrotik with 4.6 OS
when i ping the www.google.fr in the mikrotik, i receive [admin@NETLINK] > ping www.google.fr
invalid value for argument address
but i don’t know why then the ping in www.yahoo.fr is reacheable
Can you help me about this problème of unruncheable of www.google.fr
THanks for your prompt response
Try typing it this way from a terminal window:
ping [:resolve www.google.fr]
Do you have any luck?
when i type that i receive this response
[admin@NETLINK] > ping [:resolve www.google.fr]
66.102.9.104 64 byte ping: ttl=48 time=148 ms
66.102.9.104 64 byte ping: ttl=48 time=155 ms
66.102.9.104 64 byte ping: ttl=48 time=146 ms
66.102.9.104 64 byte ping: ttl=48 time=149 ms
66.102.9.104 64 byte ping: ttl=48 time=154 ms
66.102.9.104 64 byte ping: ttl=48 time=144 ms
66.102.9.104 64 byte ping: ttl=48 time=174 ms
66.102.9.104 64 byte ping: ttl=48 time=147 ms
now it is ok
when i do that ping www.google.fr
i receive
ping www.google.fr
66.102.9.104 64 byte ping: ttl=48 time=158 ms
66.102.9.104 64 byte ping: ttl=48 time=152 ms
66.102.9.104 64 byte ping: ttl=48 time=151 ms
WHAT IS the problem with google ??
flush dns
put this DNS’s
8.8.8.8
8.8.4.4
it will work
