Hi, I have an RB532 running 2.9.38. When it boots, I hit “any key” within 2 seconds to get boot menu, hit -r to reset the config, but it does nothing. I’ve tried holding the reset button in and booting power, no effect. How can I reset this board to factory?
Hi John,
Use Netinstall and reinstall ROS while wiping the config.
Tom
Yep, that did the trick, reloading OS resets the board.
Thanks!
John
