I recently enabled DNSSEC validation on our DNS server internally and just as I enabled it I can’t resolve any Cloud IP addresses anymore and it is Only this domain I have problem with.
When I do a nslookup for xxxxxxxxx.sn.mynetname.net I just get a Server failed
as a response. When I disable DNSSEC validation it works fine.
If I check the DNS Servers for mynetname.net I get that the PTR records are kind of misconfigured, they are not accessible over TCP on port 53 and ns1.kissthenet.net and ns2.kissthenet.net doesn’t seem to be entirely synced as they have different SOA serials.
There are no records for DNSSEC for this domain so I’m not really sure why it fails when enabling it, unless the queries goes over TCP when validation is enabled.
Can anyone confirm that they can lookup IP Cloud addresses when then have DNSSEC verification enabled on a Windows Server DNS?
There has been hundreds of lookups to other domains without any problem so something is not right here.
C:\>nslookup
Default Server: internal.dns.domain.local
Address: 192.168.1.2
> server ns1.kissthenet.net
Default Server: ns1.kissthenet.net
Addresses: 2a02:610:7501:1000::201
159.148.147.201
> xxxxxxxxxx.sn.mynetname.net
159.148.147.201
*** ns1.kissthenet.net can't find xxxxxxxxxx.sn.mynetname.net: No response from server
If I try the exact same on a Linux machine it works just fine so I’m not sure why there is a problem here.
And if I just ping the address it works just fine but as soon as I enable DNSSEC validation on my Windows DNS Server it stops working just like with nslookup.
Can anyone try this with nslookup on their own machines and see if you get the same result?
I’m not really sure if it’s a Windows DNS issue or an issue the the ns1.kissthenet.net nameserver but since I can only reproduce this problem with this nameserver it feels like it’s leaning more towards something wrong with the nameserver. And the problem might as well be that the nameserver doesn’t accept TCP on port 53 in the end.
EDIT:
So this specific issue with nslookup seems to be a bug in the Windows version as I get the same error when trying to query google.com to ns1.google.com as well.
The issue still stands with the Windows DNS Server not being able to lookup the domain when DNSSEC validation is enabled for some reason and I think it’s because TCP on port 53 isn’t open.
systemd-resolved also bugs out and firefox throws a non-descript error due to this…probably won’t be buying a mikrotik next, after IPv6 being manged and corrupted on v7 firmware, UPnP has fixable security issues (like not validate clients IP against the requested IP, adding port 0 as a rule), RouterOS seems more of a liability at this point. Probably flash openWRT to get functioning IPv6 and CODEL/CAKE working.
You can see here the router throws a SERVFAIL, and then second request works without DNSSEC stuff. dig directly to the configured server works fine as per the last query:
