I’m trying to use wireguard vpn and I’ve configured everything and it worked perfectly yesterday but today out of nowhere it’s started sending handshake timeout error ugh..
i tried changing MTU, changing allowed ips re-follow every tutorial but nothing helps, tried using windows PC and iPhone to connect same issue,
here are my config
# 2023-07-25 16:57:02 by RouterOS 7.10.2
# software id = S60Y-ELTX
# model = RB952Ui-5ac2nD
# serial number = should have been removed ... your moderator
add name=BR_LAN
add name=BR_VPN
set [ find default-name=ether1 ] name=P1_WAN
set [ find default-name=ether2 ] name=P2
set [ find default-name=ether3 ] name=P3
set [ find default-name=ether4 ] name=P4
set [ find default-name=ether5 ] name=P5
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country=egypt mode=ap-bridge \
name=WiFi_5G ssid=MikroTik5G wireless-protocol=802.11 wps-mode=disabled
/interface wireguard
add listen-port=8010 mtu=1450 name=WG
add name=WAN
add name=LAN
add authentication-types=wpa2-psk mode=dynamic-keys name=WiFi-Default \
supplicant-identity=""
add authentication-types=wpa2-psk mode=dynamic-keys name=WiFi_IoT \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=egypt disabled=no \
installation=indoor mode=ap-bridge name=WiFi_2.4G security-profile=\
WiFi-Default ssid=Barayez_Wi-Fi wireless-protocol=802.11 wps-mode=\
disabled
add disabled=no keepalive-frames=disabled mac-address=DE:2C:6E:4B:01:A4 \
master-interface=WiFi_2.4G multicast-buffering=disabled name=WiFi_IoT \
security-profile=WiFi_IoT ssid=Barayez_Wi-Fi_IoT wds-cost-range=0 \
wds-default-cost=0 wps-mode=disabled
/ip hotspot profile
add name=DHCP_LAN ranges=10.0.10.1-10.0.10.253
add name=WiFi_2.4_Pool ranges=10.0.1.1-10.0.1.253
add name=WiFi_IoT ranges=10.0.100.1-10.0.100.253
add name=DHCP_VPN ranges=10.0.200.1-10.0.200.253
add add-arp=yes address-pool=DHCP_LAN interface=BR_LAN name=LAN
add add-arp=yes address-pool=WiFi_2.4_Pool insert-queue-before=bottom \
interface=WiFi_2.4G lease-time=15m name=WiFi_2.4
add add-arp=yes address-pool=WiFi_IoT interface=WiFi_IoT lease-time=15m name=\
WiFi_IoT
add add-arp=yes address-pool=DHCP_VPN interface=BR_VPN lease-time=15m name=\
DHCP_VPN
/ppp profile
add change-tcp-mss=yes local-address=DHCP_VPN name=Default_L2TP \
remote-address=DHCP_VPN use-encryption=yes
add name=Admin_AhmedMohsen remote-address=10.0.200.20
set *FFFFFFFE local-address=DHCP_VPN remote-address=DHCP_VPN
/system logging action
set 0 memory-lines=4000
set 3 remote=XX.XX.XX.XX
add name=FullLog remote=XX.XX.XX.XX target=remote
add bridge=BR_LAN interface=P3
add bridge=BR_LAN interface=P2
add bridge=BR_LAN interface=P4
add bridge=BR_LAN interface=P5
/interface l2tp-server server
set default-profile=Default_L2TP enabled=yes one-session-per-host=yes \
use-ipsec=yes
add interface=P2 list=LAN
add interface=P1_WAN list=WAN
add interface=WiFi_2.4G list=LAN
/interface sstp-server server
set default-profile=default-encryption
/interface wireguard peers
add allowed-address=\
10.0.200.5/32,10.0.1.254/24,10.0.10.254/24,10.0.200.254/24 interface=WG \
public-key="ygqBs4M48zJAzCgGba5vB6egRdLoIVkhZ/THYLeM9jk="
add allowed-address=10.0.200.10/32 interface=WG public-key=\
"M3/NIFqrJi2Ye0kA9PFzJv8xvQQf0fiSZtGVpH7VbQE="
add address=10.0.10.254/24 interface=P2 network=10.0.10.0
add address=10.0.1.254/24 interface=WiFi_2.4G network=10.0.1.0
add address=10.0.100.254/24 interface=WiFi_IoT network=10.0.100.0
add address=10.0.200.254/24 interface=WG network=10.0.200.0
add address=10.0.200.254/24 interface=BR_VPN network=10.0.200.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add interface=WiFi_5G
/ip dhcp-server lease
add address=10.0.1.245 mac-address=D8:DC:40:BE:3A:3E server=WiFi_2.4
add address=10.0.1.0/24 dns-server=10.0.1.254 gateway=10.0.1.254
add address=10.0.10.0/24 dns-server=10.0.10.254 gateway=10.0.10.254 netmask=\
24
add address=10.0.100.0/24 gateway=10.0.100.254
set allow-remote-requests=yes servers=129.153.173.26,129.153.173.26
/ip firewall address-list
add address=10.0.10.0/24 list=Local_IPs
add address=10.0.1.0/24 list=Local_IPs
add address=10.0.200.0/24 list=Local_IPs
add address=10.0.200.5 list=Management_IPs
add address=10.0.1.245 list=Management_IPs
add address=10.0.1.254 list=Admin_IPs
add address=10.0.10.254 list=Admin_IPs
add address=172.0.0.1 list=Admin_IPs
add address=172.0.0.254 list=Admin_IPs
add address=10.0.200.20 list=Management_IPs
add action=accept chain=input comment="Allow L2TP" dst-port=500 protocol=udp
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=1701 protocol=udp
add action=accept chain=input comment="Allow WG port" dst-port=8010 log=yes \
log-prefix=WG protocol=udp
add action=accept chain=forward comment="Allow Self DNS" dst-address=\
129.153.173.26 dst-port=53 protocol=tcp
add action=accept chain=forward dst-address=129.153.173.26 dst-port=53 \
protocol=udp
add action=accept chain=forward comment="Allow iPhone to bypass DNS" \
dst-port=53 protocol=udp src-mac-address=D8:DC:40:BE:3A:3E
"Allow managers IPs to acess admin IPs" dst-address-list=Admin_IPs \
src-address-list=Management_IPs
add action=accept chain=input dst-address-list=Admin_IPs src-address-list=\
Management_IPs
add action=drop chain=forward comment="Drop Any Diff DNS" dst-port=53 log=yes \
log-prefix="Drop Any Diff DNS" protocol=tcp
add action=drop chain=forward dst-port=53 log=yes log-prefix=\
"Drop Any Diff DNS" protocol=udp
add action=drop chain=forward comment="Block access to modem IPs" \
dst-address=172.0.0.0/24 log=yes log-prefix="Block access to modem IPs"
add action=drop chain=input comment="Block access to WebGUI from WAN" \
dst-port=8005 log=yes log-prefix="Block access to WebGUI from WAN" \
protocol=tcp src-address-list=!Management_IPs
add action=drop chain=input comment="Block access to web gui from GUI IP" \
dst-address=172.0.0.1 dst-port=8005 log=yes log-prefix=\
"Block access to webgui from GUI IP" protocol=tcp
add action=drop chain=input comment="Block access to winbox from WAN" \
disabled=yes dst-port=8200 log=yes log-prefix=\
"Block access to winbox from WAN" protocol=tcp src-address-list=\
!Local_IPs
add action=drop chain=input comment="Block access to telnet from WAN" \
dst-port=2003 log=yes log-prefix="Block access to telnet from WAN" \
add action=drop chain=input comment="Block access to ssh from WAN" dst-port=\
2002 log=yes log-prefix="Block access to ssh from WAN" protocol=tcp \
add action=masquerade chain=srcnat out-interface=P1_WAN
add action=dst-nat chain=dstnat disabled=yes dst-port=8010 in-interface=\
P1_WAN protocol=udp to-addresses=10.0.200.254 to-ports=8010
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip service
set telnet port=2003
set ftp address=0.0.0.0/0 disabled=yes port=8010
set www port=8005
set ssh port=2002
set api disabled=yes
set winbox port=8200
set api-ssl disabled=yes
/ppp secret
add name=ahmed.mohsen profile=Admin_AhmedMohsen service=l2tp
/system clock
set time-zone-name=Africa/Cairo
/system identity
set name=KEK-MTK
/system logging
add action=remote topics=info
add action=remote topics=system
add action=remote topics=critical
add action=remote topics=error
add action=remote topics=warning
add action=remote topics=dhcp
add action=remote topics=e-mail
add action=remote topics=firewall
add action=FullLog disabled=yes topics=!ups
