I admit this is most probably user error. I've written config import scripts before, but not automation. I can not get "/system script run scriptName" to function
RB951Ui-2HnD v6.40.2
Attempt to execute via file name, as other forum posts say is supposed to work
[scripttest@device] > /system script run test.rsc
no such item
Look at help. It says I need to use the file
-- Item number
List files (full list not posted here, for brevity)
[scripttest@device] > /file print
NAME TYPE SIZE CREATION-TIME
0 pub directory aug/31/2017 20:43:11
1 skins directory dec/31/1969 18:00:02
<..snip..>
12 log.2.txt .txt file 171.1KiB sep/01/2017 18:34:58
13 test.rsc script 2575 sep/04/2017 12:12:02
14 log.1.txt .txt file 173.3KiB sep/04/2017 09:09:40
I want # 13, try that. no dice
[scripttest@device] > /system script run 13
no such item
Try a known bad file entry, same result
[scripttest@device] > /system script run 0
no such item
Try another known bad, non-existant file. Same result
[scripttest@device] > /system script run test22222
no such item
I would appreciate any pointers as to what am I doing wrong. Thanks!
