Can't see all settings
Hi
I found a problem at the export output. My hardware is a RB2011.
add disabled=no ports=switch2-cpu,ether6-master switch=switch2 vlan-id=22
add disabled=no independent-learning=yes ports=switch1-cpu,ether1-master,ether2,ether3 switch=switch1 vlan-id=99
But independent-learning=yes is set at the first entry too.
Is this a bug?
