Cant see LHG LTE6 behind RB951Ui-2nD
Hello everyone!
I got a strange problem… Im currently trying to upgrade my home internet with a LHG LTE6 und a RB951Ui-2nD.
The Problem is i cant access the LHG LTE6 via WinBox, both IP and MAC simply does not work. Ping also does not work.
I can see the LHG in the Neighbor List on the RB951Ui-2nD and also can MAC Ping and MAC Telnet from there, normal Ping and Telnet does not work.
Whats really weird to me is that i have internet access, but only partially, like Google gives me Timeout, Mikrotik Forum working fine (wtf?).
Configs:
 Config of RB951-Ui-2nD:
/export
# apr/29/2020 17:41:00 by RouterOS 6.46.5
# software id = XXXX-XXXX
# model = 951Ui-2nD
# serial number = XXX
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=austria disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    "Aurora Australis" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=XXX wpa2-pre-shared-key=\
    XXX
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
set discover-interface-list=all
add interface=ether1 list=WAN
add address=192.168.88.2/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.2 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.2 comment=defconf name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=Router
Config of LHG LTE6
/export
# apr/29/2020 17:44:05 by RouterOS 6.44.5
# model = RBLHGR
/interface lte
set [ find ] mac-address=XX:XX:XX:XX:XX:XX mtu=1480 name=lte1
add address-pool=default-dhcp disabled=no interface=ether1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
/ip dns static
add address=192.168.88.1 name=router.lan
/system clock
/tool mac-server
/tool mac-server mac-winbox
I already tried serveral resets of both devices but always the same outcome.
Do i oversee something?
Thanks in advance to everyone who can help!
Just connect PC directly instead RB951 and try WinBox then.
From RB951 not works the Mac-Telnet ?
Next time run RoMON.
