Can't see USB port, but can see USB modem?
Hi, everybody! I’ve just unpacked new 951G and try to set up 3G to WiFi internet connection.
I’m going through few manuals about it, but my router gives different results. It does not see USB port under ports. And I have no idea how to make it see. Any ideas?
  [admin@MikroTik] > /system resource usb print
 # DEVICE VENDOR                  NAME                SPEED
 0 1:1                            RB400 EHCI          480 Mbps
 1 1:4    China TeleCom           CBP7.1              12 Mbps
[admin@MikroTik] > /port print
Flags: I - inactive
 #   NAME                     CHANNELS USED-BY                   BAUD-RATE
[admin@MikroTik] >
Your 3G modem is not supported by RouterOS, hence that results.
http://wiki.mikrotik.com/wiki/Supported_Hardware#3G_cards
Regards,
ditonet, thank you! I’ve tried with different 3G stick — worked!
