I'm trying to use DHCPv6 to hand out addresses to clients on the LAN side of my router. I seem to have no problem with clients using ND/RA to generate their own addresses, but I never see any entries in DHCPv6. I was handing out /64's on the same range as the RA so I'm guessing that may be part of the problem, but I'm not sure how to overcome that? I tried handing out shorter addresses via DHCPv6 and that didn't seem to work. My current config is:
[tim@RouterDawg] /ipv6 address> print
Flags: X - disabled, I - invalid, D - dynamic, G - global, L - link-local
ADDRESS FROM-... INTERFACE ADV
0 DL fe80::4e5e:cff:fe9e:9912/64 Port 1 - WAN no
1 DL fe80::4e5e:cff:fe9e:991b/64 LAN Bridge no
2 G :1e0::2/64 Port 1 - WAN yes
3 G :1ef::1/64 LAN Bridge yes
[tim@RouterDawg] /ipv6 nd> print
Flags: X - disabled, I - invalid, * - default
0 * interface=LAN Bridge ra-interval=3m20s-10m ra-delay=3s mtu=unspecified
reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m
hop-limit=unspecified advertise-mac-address=yes advertise-dns=yes
managed-address-configuration=yes other-configuration=no
[tim@RouterDawg] /ipv6> dhcp-server
[tim@RouterDawg] /ipv6 dhcp-server> print
Flags: D - dynamic, X - disabled, I - invalid
NAME INTERFACE ADDRESS-POOL LEASE-TIME
0 LANv6 LAN Bridge LAN Delegation 3d
[tim@RouterDawg] /ipv6 pool> print
Flags: D - dynamic
NAME PREFIX PREFIX-LENGTH EXPIRES-AFTER
0 LAN2 :1ee::/64 64
1 LAN... :1ef::/64 64
Any ideas on how I might go about making this work? I use AT&T and they seem to be handing out a /61 or something like that, so I think I can carve out subnets if I had to, though I tried that (as you can see from the LAN2 pool) but still no dice.
I'm using OS X Yosemite to test. It's my laptop and one I'd like to use DHCPv6 on so I can hand off the same addresses as I want to add some IP-based security around iSCSI.
Any ideas?
