Can't set DNS servers into my SXT Lite5
As you can see in the screenshot below,
in that box I’m not able to set my DNS servers, as I click “apply” nothing is being saved.
You can try with winbox.
this is winbox!
might be a bug in winbox
have you tryied to add the dns from the terminal?
No, I’ve not tried yet, but if it’s a bug is a real trouble.
Someone have experienced that?
Sent from my iPhone using Tapatalk - now Free
Nobody knows that?
you can try to close window and re-open it. This might help. in 6.5 will be fixed.
how can I start a terminal? Via ssh?
Which is command to set dns addresses?
yes, or via new terminal in winbox (it opens a telnet session)
/ip dns set servers=
