Can't set route distance on dynamic link
I have my MT configured for 2 IPS’s on ether1 and ether2.
Ether1 uses a static IP from my ISP and I want it to be the primary connection.
Ether2 uses a dynamic IP from ISP #2 and I want it to be secondary.
When I go to IP > Routes to set the distance for the dynamic link, everything is greyed out and I can’t set it.
How can I do this?
attachment=0]dip.jpg[/attachment]
How are you setting the routes…
Are you using IP DHCP client for both or just ISP 2 etc…
Need to see the config
/export file=anynameyouwish ( minus router serial# and any publicWANIP information)
as anav said, u can manage that here:
/ip dhcp-client/set default-route-distance=x
# jan/26/2023 09:40:55 by RouterOS 6.49.7
# software id = ZRRP-QJKG
# model = RB2011iL
# serial number = xxx123xxx123
add name=bridge3-10
set [ find default-name=ether1 ] comment=FIBER
set [ find default-name=ether2 ] comment=VERIZON
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.2.100-192.168.2.250
add address-pool=dhcp disabled=no interface=bridge3-10 lease-time=10h name=\
    dhcp1
add bridge=bridge3-10 interface=ether4
add bridge=bridge3-10 interface=ether5
add bridge=bridge3-10 interface=ether6
add bridge=bridge3-10 interface=ether7
add bridge=bridge3-10 interface=ether8
add bridge=bridge3-10 interface=ether9
add bridge=bridge3-10 interface=ether10
add bridge=bridge3-10 interface=ether3
add interface=ether1 list=WAN
add list=LAN
add interface=bridge3-10 list=LAN
add address=192.168.4.101/24 interface=ether1 network=192.168.4.0
add address=192.168.2.1/24 interface=bridge3-10 network=192.168.2.0
/ip dhcp-client
add comment=VERIZON disabled=no interface=ether2
add address=192.168.2.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.2.1
set servers=1.1.1.1,8.8.8.8
add action=masquerade chain=srcnat comment=FIBER out-interface=ether1 \
    src-address=192.168.2.0/24
add action=masquerade chain=srcnat comment=VERIZON out-interface=ether2 \
add check-gateway=ping distance=1 gateway=192.168.4.1
/ip service
set telnet disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/Chicago
Paste this on terminal:
/ip dhcp-client
set [find where comment=VERIZON and interface=ether2] default-route-distance=10
If something is dynamic, like the route created from dhcp-client, you must go where the route is created, on this case the dhcp-client.
what does it want for “numbers” ?
Ignore, he wrote it without even checking what he wrote…
