Can't set up 1Gbps link with ISP (hAP AC)
Hi all.
I have direct cable from ISP that goes to my mikrotik hAP AC to ether1. The link establishes only at 100Mbps rate. If I plug the cable directly to my PC the link is 1Gbps.
Today I had a visit from ISP technical and we doublchecked the wires from their hardware. Everything is fine on their side.
Below is result of /export hide-sensitive command.
[MeSaNei@MikroTik] > /export hide-sensitive
# jul/16/2017 10:23:09 by RouterOS 6.39.2
# software id = HPXI-PC69
add admin-mac=64:D1:54:19:FD:79 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country=russia disabled=no distance=indoors frequency=auto mode=ap-bridge \
    ssid=MeSaNei wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
    ssid=MeSaNei5 wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
    ether1
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=\
    ether1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/tool mac-server
/tool mac-server mac-winbox
