Can't SSH from CHR Version 7.0 Beta 3
I am unable to SSH from my CHR running v7.0 Beta 3. I upgraded from version 6.46beta55 using the file https://download.mikrotik.com/routeros/7.0beta3/routeros-7.0beta3.npk. Below is my SSH config the rest of my config is quite long but I can attach if necessary.
/ip ssh
set forwarding-enabled=both strong-crypto=yes
Here is the error when I try and ssh to my rasberry pi
[admin@MikroTik] > /sys ssh user=pi 10.22.87.20
Server returned smaller prime for DH exchange than requested: 3
What is the remote device? If it is RouterOS does it have strong-crypto enabled too? If it is not ROS devices, does it have enabled all needed algorithms that is used by the ssh client when strong crypto is enabled?
I have tried to SSH to another mikrotik deivce that has strong crypto enabled. I have also tried to SSH to my Proxmox host running version 6 which has the up to date crypto and hash enabled. I get the same result no matter what I try and SSH to.
Problem will be solved in next beta.
