I have moved house and went from a static IP on my ADSL connection to a new service also with a static IP.
The funny thing is that I can’t seem to get the static IP that the ISP gave me to work - whenever I configure it under ‘IP/Addresses’ in the GUI against the pppoe-out1 interface it automatically adds in a DHCP IP for the pppoe-out1 interface and relegates the one I created to ether1-gateway.
Output of a few commands below showing that DHCP is off for all interfaces…
I have a welcome email from my ISP stating that I do, again, have a static IP. Can anyone offer any suggestions on how to stop pppoe-out1 from gaining a DHCP address ?
That address (220.244.77.236/32) is being given via DHCP.
The ISP has sent a welcome email stating a different static address that I should be using.
Each time I configure this (different) static IP address again pppoe-out1 the RB750G changes this static address to be ether1-gateway and adds in the Dynamic address against pppoe-out1.
PPPoE uses PPP to obtain an address from PPPoE server. it obtains 220.244.77.236 for now. ask your ISP to recheck their settings and to look at their logs
OK - will do that. I thought that I had configured this static IP address somewhere last time I was with this ISP. Maybe not !
Out of interest - I have had cheaper Linksys routers that also do pppoe but also allow me to specify a static IP address. How does this work if it is PPP that is handing out IP addresses ? Cheers.
Hi - I created the new profile with the static IP as ‘Local Address’ and it worked fine for incoming SSH traffic (tested via phone) but I can’t get any traffic out of the network with it enabled this way.
I have worked out that no default route is being added when I use the profile set up with the local address.
sounds like a bug - it must depend on ‘Add Default Route’ tick, not on custom address in Profile if you can repeat this behaviour - please send this into to support@mikrotik.com
When I add the ppp profile and then add the local IP ( my static ip ) I can not get Internet access because there is no default route being added. However, in this configuration I can connect in to this static ip via ssh.
