hello,
[topic copyed from routerboard forum]
I have two PC stations (P4 2,4GHz) with mikrotik 2.9.27.
This is config one station:
interface wireless> print
interface-type=Atheros AR5213
mode=nstreme-dual-slave
frequency-mode=superchannel
antenna-gain=0
tx-power-mode=default
compression=no allow-sharedkey=no
interface wireless nstreme-dual> print
arp=enabled
disable-running-check=no
tx-band=5ghz
tx-frequency=5600
rx-band=5ghz
rx-frequency=5360
rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
framer-policy=exact-size
framer-limit=4000
interface wireless nstreme-dual> monitor 0
tx-signal-strength: -56dBm
rx-rate: 36Mbps
tx-rate: 48Mbps
connected: yes
rx-signal-strength: -63dBm
tx-signal-strength: -58dBm
rx-rate: 36Mbps
tx-rate: 54Mbps
connected: yes
rx-rate: 36Mbps
tx-rate: 54Mbps
connected: yes
rx-signal-strength: -62dBm
rx-rate: 36Mbps
tx-rate: 48Mbps
connected: yes
system resource> monitor
cpu-used: 36
free-memory: 242564
cpu-used: 39
free-memory: 242564
cpu-used: 37
free-memory: 242564
cpu-used: 46
free-memory: 242564
cpu-used: 30
free-memory: 242564
Why have I so poor connection?
Last year i had 54/54Mbps posibility to use band=5ghz-turbo now i can’t turn on turbo mode.
Could you tell me what 5ghz mPCI cards have posibility to turn on turbo mode on mikrotik 2.9.27? I have to pass 40mbps fdx by this bridge. I changed framer-policy but without effect.
Can I do anything?
