Hi all,
I’ve always had an IPSec tunnel between two Mikrotiks (using public IP) and everything has always worked well.
Today I had to change one of two public IP designated for tunnel, I updated the configuration with the new IP in the peer, the NAT, the Route etc.
The Peer is established correctly (Active Peers > State=established). The problem is that the Installed SAs still remain with old IP, so the Phase 2 is not successful.
I’ve already tried to reboot both Mikrotik and also use Flush button, but the Installed SAs still remain with old IP.
Have you also updated the sa-dst-address in /ip ipsec policy? If yes, post both configurations, see my automatic signature below regarding anonymisation.
If disabling and re-enabling one of the peers doesn’t help, post your configuration exports (check my automatic signature below for anonymization hints). If you cannot change sa-dst-address manually, it had to be created dynamically and thus it should follow peer address.
Looks like there is still a bug with dynamic policies and addresses. I am suffering a similar issue where I have duplicate policies, one with old dynamic address, one with new dynamic address. I am already in contact with Mikrotik support.
