Cant Update Wifi Extender
Introductions
I have been using Mikrotik for years and slowly migrated most of my family to use it, but I am not a network person and generally only do the basics and often used wizard and default configs where possible. I am very comfortable on a Linux CLI but all at see on the Mikrotik console and so generally prefer the web GUI.
One problem that I have never been able to solve that I have made my 2025 new years resolution to solve and understand is that I am unable to upgrade my wifi extenders.
Setup
The setup is simple. One Mikrotik device as the main gateway and DHCP device and then one or more wifi extenders.
When using RouterOS 6 I used the auto setup wizard for creating an extender but since upgrading hardware and using RouterOS 7 I manually created a repeater setup on top of a default config using the RouterOS 6 setup as a reference to copy.
Problem
In both versions of my setups v6 and v7 the wifi extenders are unable to do updates. Its as if the device has no gateway but clients that connect via wifi can access the internet just fine.
The error I get is one of two versions connection timeout or DNS cant resolve. The timeout version seems to be on my v7 setup and the DNS error on my v6 setups.
The odd thing for me is that even if I take the router and plug in ether1 directly into the gateway device it still cant upgrade.
Any guidance would be greatly appreciated.
Any config would be greatly appreciated :slight_smile:
Following anav’s advice please provide us both exported configs:
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys etc. )
@BartoszP is this what you where expecting.
# 2025-01-03 16:56:04 by RouterOS 7.12.1
# software id = xx
# model = xx-xx
# serial number = xx
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment="5G Networked" name=\
    bridge1
add comment="2G 8 8a8e8bridge2
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-XXX-G5
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-XXX-2
/interface wifiwave2 configuration
add disabled=no name=cfg-N5 security=sec-XXX-G5 ssid=XXX-G5
add datapath.client-isolation=yes disabled=no name=cfg-2 security=\
    sec-XXX-G2 ssid=XXX
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz comment="XXX-5 Station" configuration=\
    cfg-N5 configuration.mode=station-bridge disabled=no
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz comment="XXX Station" configuration=cfg-2 \
    configuration.mode=station-bridge .ssid=XXX disabled=no
add comment="XXX N5 AP" configuration=cfg-N5 configuration.mode=ap \
    disabled=no mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi1 name=\
    wifi3
add comment="XXX AP" configuration=cfg-2 configuration.mode=ap disabled=no \
    mac-address=XX:XX:XX:XX:XX:XX master-interface=wifi2 name=wifi4
add address-pool=default-dhcp disabled=yes interface=bridge1 lease-time=10m \
    name=defconf
add bridge=bridge2 comment=defconf interface=ether2
add bridge=bridge2 comment=defconf interface=ether3
add bridge=bridge2 comment=defconf interface=ether4
add bridge=bridge2 comment=defconf interface=ether5
add bridge=bridge1 comment=defconf interface=wifi1
add bridge=bridge2 comment=defconf interface=wifi2
add bridge=bridge1 interface=wifi3
add bridge=bridge2 interface=wifi4
add comment=defconf interface=bridge1 list=LAN
add address=192.168.1.4/24 interface=bridge2 network=192.168.1.0
add address=192.168.0.4/24 interface=bridge1 network=192.168.0.0
/ip dhcp-client
add interface=bridge1
add interface=bridge2
    192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
    established,related,untracked disabled=yes
    invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    "defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
    disabled=yes in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes hw-offload=yes
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set www-ssl certificate=WebFig disabled=no
set api disabled=yes
set api-ssl certificate=WebFig
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system identity
set name="XXX-RB x2"
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
You have BOTH a static IP address AND a DHCP client running on both bridges:
/ip dhcp-client
This may (or may not) “confuse” the routes, depending on what is provided by the DHCP server.
Post the output of:
/ip route print
I remember setting this and seeing this, but never thought it was a problem.
Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, d - DHCP; + - ECMP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
     DST-ADDRESS     GATEWAY      DISTANCE
DAd+ 0.0.0.0/0       192.168.0.1         1
DAd+ 0.0.0.0/0       192.168.1.1         1
DAc+ 192.168.0.0/24  bridge1             0
DAc+ 192.168.1.0/24  bridge2             0
The DHCP Client and static IP’s seems to explain the difference between the two errors I have been getting (timeouts vs DNS).
After disabling the DHCP client on both bridges my error went from a timeout to Error: could not resolve dns name when trying to check for updated packages.
Routes now look like this.
DAc 192.168.0.0/24  bridge1         0
DAc 192.168.1.0/24  bridge2         0
Well, in this configuration:
You have two routes towards “internet” through two different gateways (they are so-called ECMP routes, marked by the + sign), if (as I suspect) only one or the two is actually the gateway to the internet, this may create issues, as the router will choose the one or the other, but the main issue is that seemingly you have not configured the interface to the modem/router/internet (possibly ether1?):
add comment=defconf > interface=ether1 list=WAN
In this configuration (With DHCP disabled and only the static addresses set to the bridges):
you have no route to the “internet” at all, the two LAN routes, one for each bridge are DAc (Dynamic Active connected) and come from the two IP addresses you gave (manually) to the two bridges (and are fine).
You need to add a static route, through the interface that is actually connected to the router/modem/internet, possibly ether1, which right now has not even an Ip address, or add ether1 as dhcp client, or if one of the two bridges is connected “upstream”, then add only that one.
That solved it, I now understand both errors and how they happen and was able to upgrade the one networks wifi extenders and will do the others when next on site.
Thank you very much.
Good. :slight_smile:
You are welcome of course.
