zorrua
March 25, 2018, 4:55pm
1
I have a pair of SXT 5HPnD devices for a PtP link, both have 6.41.3 package version, but I can not upgrade Routerboard in one of them:
Both have Internet access and can download the Package version corretly, why I can not upgrade the Routerboard version?
Thanks for your help.
Kind regards.
zorrua
April 2, 2018, 8:40pm
2
Anyone could help me?
Need I open a case with official support?
Kind regards.
Pea
April 2, 2018, 9:57pm
3
What is in the log when you click on Upgrade button?
try through the tik app. I had the same issue, but i was able to do it through the tik app.
zorrua
April 20, 2018, 2:10pm
5
This is what I have if I click in the Upgrade button:
I rebooted but it is not upgraded.
Regards.
zorrua
April 20, 2018, 2:15pm
6
I try with tik-app, but same problem, it doesn’t upgrade.
Is there any way to upgrade from USB?
Kind regards.
mrz
April 20, 2018, 2:19pm
7
From your screenshot upgrade firmware shows 3.33, do you have custom firmware file uploaded on the router? Check files menu
zorrua
April 20, 2018, 2:27pm
8
I found this firmware: https://i.mt.lv/routerboard/files/ar7240_3.41.fwf
I uploaded to the device and now I have 3.41 version:
I have newer firmware, but still can not upgrade more.
Where could I download 6.42 firmware for my device?
Kind regards.
zorrua
April 20, 2018, 7:09pm
9
Yes!!! It works!
I have some firmware in the Files section. I delete them and now I can upgrade to the latest firmware:
Thank you very much!
Best regards.
solar77:
Kind regards.
Hi - I had this issue on a couple of Discs (RBDiscG-5acD) running older versions. Clients. The issue was with Nstreme. I switched the AP to nv2 and then they updated normally by using System->Packages in the GUI with no issues. Updated to 6.46.2.
