cAP 2n maximum clients
Hi guys,
Do you know how many devices can connect simultaneously to the Mikrotik cAP 2n? Anyone with experience using this device?
http://routerboard.com/RBcAP2n
Thanks!!
Theoretically 2007 clients,
It depends on the client’s signal strength towards the CAP2n,
To gain Maximum wireless connections remotely on your device,try to effect an access list (ACL) rule on signal strength,
Only Clients with good signal strength can connect.Make sure to set default-authentication=no.
Hope that it will help!
Thanks!!
