I bought a cAP ac. I need to configure it on AP mode so that it works correctly on the Hotspot I configured on my network. But, when I put the AP BRIDGE mode on the router, it doesn’t work as expected. A device connects to the wifi, pass the Hotspot login, and when a second device connects, the network doesn’t request the login to access the internet. I have other cAP acs configured in the same mode and they work perfectly, but this new one doesn’t. The configuration is exactly the same on all of the routers. I don’t know why this new one doesn’t work, since I did exactly the same on all Routers.
Obviously you did not do the same or it would act the same.
Export config from a good unit and the bad unit and compare section by section to see where the difference is.
Bridges, interfaces, VLANS.
Its probably in there or NOT in there somewhere.
