cAP ac reset not possible after netinstall
Hello and good day.
i have an issue/difficulty regarding a cAP AC device.
The problem is, that a reset of the device is not possible after using netinstall.
Procedure:
Netinstall routeros-arm-6.45.5.npk without any config- Success
Reboot (Powercycle/or from within routeros) - Success
Reset - Failure (device doesn’t come up in winbox)
LED status:
Power - always on;
Ethernet - blinking (indicating network communication);
2Ghz & 5Ghz blinking rhytmically (2secs)
Any help is very much appreciated.
Kind Regards
Jan
Problem solved :slight_smile:
The quoted post is completely useless. You should describe your solution to aide any future users with similar problem.
I’m sorry,
The whole problem dewscription was relaying on a missconfiguration at some oter point, so it couldn’t help anyone in no case.
That’s why i tryed to delete tho whole Thread. Obviously without any luck.
Would you like me to delete it for you? :slight_smile:
hi, i don’t know how to add new post so i will post my problem her as reply to this topic.
my problem is netinstall not working on windows 10,
and showing a message box say
“no code !!!: the opration completed successfule. (0)”
i tried to solve the problem with ‘’ run as admin and compatblity with win 7 but the problem still,
thank u to read my words
If you can :slight_smile:
When i tried i got a system message stating it where not possible to delete a post after it was already replyed.
