I am completely new to the whole MikroTik hardware and also (probably) a complete newbie in terms of networking.
My last setup (private house):
FritzBox 7560 as internet router
Netgear GS324PP as switch
FritzBox 7362 SL as Wifi Mesh extender connected via LAN
I now wanted to simply change hardware from the FritzBox 7362 SL to the MikroTik cAP ac, which was recommended by a friend of mine. The cAP ac was intended to replace the FritzBox and initially simply work as an AccessPoint to the above mentioned hardware. The plan was to plug the ethernet PoE cable into the cAP ac, do some minor tweaks (setting SSIDs, passwords, potential frequency ranges,…) and let it run. However, I am somehow not able to get it working and now realized that I underestimated the knowledge required to setup the cAP ac.
When I plug the external PoE injector to LAN1 and the coneection to the Netgear switch into LAN2 everything seems to work as expected. My intention was to use the PoE supply from the switch itself and therefore only plug that cable into LAN1. However, when I do this, the cAP ac is not anymore accessible via WinBox nor can I access it from anywhere else. I assume, that some settings are blocking LAN1 from being a “normal” switch connection.
I want all ports to be bridged (Wifi to LAN and vice versa) as well as Wifi on 2.4 and 5 Ghz.
I would be very grateful for any help. If you require more information, please tell me.
Although the capac can act like a router its really best suited as an AP.
If you wanted a combo unit you should have purchased a hapac2 for $69 or a hapac3 for $99 compared to the capac at $69.
I too am not convinced that using other vendors POE on the capac will always work.
I am using a TPLINKswitch to do the same and have had no problems with connectivity and power but the TPlink switch sometimes reboots and wondering if this is connected to the capac connection so right now using the capac supplied infector for testing.
Recommend you do the same while ensuring connection configuration. That way you eliminate POE as part of the problem.
Well yes one should configure the capac via laptop first to setup it up for the correct bridge and management setup and lanip address so that it is accessible via winbox on the network.
I also like to setup lan2 as a separate LANIP address only so that I can access it separately via laptop in case my bridge config goes funky which has happened on many an occasion while frigging with it.
Note the access on lan2 is easy if you can remove the capac without isssue, IF the capac is in a more difficult spot try to run a cable from lan2 to a reachable spot for this backup plan.
Nope, On my capac, no firewall rules.
Just ensure its LANIP is on the management or home lan.
ether1 and wlans are on the bridge,
eth2 has its own address not associated with the bridge for emerg access
put in a route manually 0.0.0.0/0 gateway=management or homelan gateway
