cAP AC sync system time
i wanted to install an ntp-client on a cAP AC, but it seems to be that the device will sync the systemtime over CAPsMAN automatically. Is this correct, or do I need to configure a ntp client on the cAP?
I cannot find any configuration in cAP config file
Christian
/system ntp client
set enabled=yes primary-ntp=193.140.100.40 secondary-ntp=217.198.219.102
And disable sync time in /ip cloud. There were sync issues before. Probably fixed now but why have two sources right?
Sent from Tapatalk
the cAP is managed by capsman and my question was, if the cAPS will sync automatically via capsman, without any additional config on the cAP.
Sync time in /ip cloud is enabled (by default), but from which source is it synchronized, from internet? If yes, is it better to add the local router (RB3011) as timeserver with this command?
/system ntp client
set enabled=yes primary-ntp=<gw-Address>
Christian
