it might be a stupid question but what would be the recommended installation for the cAP ac?
vertical? horizontal? doesn’t matter?
thanks
thanks
Your installation site matters. Check out the beam formation pattern of the devices and compare to your installation case. You risk having a weak signal on one side while it goes to waste on the other.
