I searched and read Cap AP threads and seems it either works or not. Mine is not.
Situation, private house, 4G+ Huawei B535 router, only 2,4 GHz enabled, Huawei > LAN > RB750GL > Engenius EAP300. Speed was 20-25 down/up. As EAP supports only 100MB LAN and 2,4 GHz, I decided to change it to Cap AC. Configured Cap AC it as router, Huawei > eth1 (wan), eth2 (lan) > 1G switch > Lenovo X230. Huawei is located at the second floor, about 8 m from where I test (I’m the only user). Cap AC is located 3 m away.
Using LAN (true Cap AC) or Huawei I get 50-70 down and 35-45 up, no matter, LAN or WiFi, speed is same.
Using Cap AC, I can barely get 15-20 down and strangely 30-40 up.
This is even worst than Engenius can do, even more, my very old Buffalo WHR-HP-G54 can do better.
Firmware 6.46.5, current (I tried all kind settings, no luck) conf is:
5 meters, sounds hard to believe. Are you sure the client device is not the issue? 5Ghz should work fine even on opposite end of your building, with phone as client. Try to test other devices connected to it.
Ok, I probably I exaggerated a bit about 5Ghz coverage, but let’s concentrate the 2,4 Ghz issue. How the fix the 2,4GHz speed. I tested with multiple devices, they all give same result, Huawei & 2,4GHz = all OK, Cap AC & 2,4GHz = all NOK.
For 2.4GHz, try use only 20MHz instead of 20/40, use wpa2 aes only, set indoor, basic rate 12/24, supported rate 12~54, enable WMM. I got a pretty good speed like about 80~95mbps, but it really depends on your environment and client
Made some more tests, laptop uses Intel Centrino Advanced-N 6205 AGN dual-band 802.11a/g/n Wi-Fi adapter that delivers speed up to 300 Mbps. Installed FileZilla FTP server into laptop and connected from other computer via 1G LAN and uploaded/downloaded 1,8GB file, and speed is about 30MB up/down.
So I have eliminated all aspects except Cap AC. So Microtik, the Cap AC is not what is should be based spec -s https://mikrotik.com/product/cap_ac
Ans as I see, that also official support is silent (they acknowledge the problem), so how to proceed as I need product that works. Mikrotik - can I send it You and get some other, better model?
MikroTik is great stuff and it requires a learning curve. There community is great and really active. For any user from beginner to master.
Good, in regards to your problem: your settings require optimization. Already mentioned by @heidarren there are some basic settings that have to be obeyed.
In regards to your remark about the performance “and speed is about 30MB up/down”. This is practically impossible on the 2G radio. Sounds to me like the test was performed on the 5G radio.
If you want some help, please first start by sharing your configuration (/export hide-sensitive). From thereon we can advice you.
Ans as I see, that also official support is silent, so how to proceed as I need product that works. Mikrotik - can I send it You and get some other, better model?
What official support are you referring to? What kind of support are you expecting? Also the more expensive models require configuration…
Correction MB > Mbps, so I get about 3 Mbps, which is very low rate. Like I said before, only 2,4Ghz is active, so what more to optimize? Current full (the wifi part was in my first post also) conf is:
I played with tx-power and nv2-downlink-ratio, without any positive result.
BTW, I have used Mikrotik products about 7 years, and with every new product I hope, that now all is OK. Last failure was hAP ac lite TC, same problem, low speed, bad 5GHz coverage. Seems nothing is improved.
After 7 years of thinking MT does everything wrong, it would be right time to invest in MTCNA and MTCWE courses to finally understand how WiFi (and MT) works. There are several really good MT lecturers in Estonia.
For free beer when we meet I give you this standard configuration. Don't mess with things you don't understand. I don't know exact numbers for 2GHz, but 5GHZ AC runs easily 40-50MB/sec downloads:
Well, As You see, every users have his own settings, claiming that these are the best, so which to choose? However, I’did import these settings now and 2,4GHz FTP download = 2,9-3,0 MB/sec 5Ghz FTP download = 4,5-5,0 MB/sec, LAN FTP download 90-92 Mb/sec. So what next?
In the last try a full reset of the device. I had a few problem with some used wap ac (with same configuration of other wap ac i have) and the reset has resolved all of them.
You have checked channel and interference? Download WiFi analyzer and check, search online what can interfere whit wifi signal - microwave, Bluetooth, wireless mice and keyboard etc.
Yes
but why you do not post your config first maybe it just some misconfiguration
export file=conifg hide-sensitive this will remove all password from the file
