Cap AC with HomePod airplay Issue
Hi All
I run a Mikrotik Hex S with 2 cap AC that I managed to provision through the router.
I have been running these for about 3 years with no issues and can use the Airplay feature from my iPhone to my Apple TV. Yesterday I purchased a HomePod and during setup for the message
Homepod featured like airplay and personal Requested my not work on"mywifi" because it does not support peer-to-peer connections.
Now I am now expert not the caps which I setup mostly with default but can anyone advise how I can get this sorted.
Without having a look at your config, no.
Most likely you are using capsman forwarding, not local forwarding ?
Is client to client forwarding enabled ?
Many thnaks
I had local forwarding on but had to enable client to client forwarding. Now works a treat, thanks
Hi there, how did you enable local forwarding adn enabled client to clienty forwarding? i too am having some issues connecting to a HomePod
