I have one router RB951G-2HnD as main without wifi on it and 6 others (also RB951G-2HnD) connected to it to cover whole building. They are in CAPs mode with two wi fi networks (ssid). One for public use (internet) and one for few selected users (private).
That works fine but, I need to setup bandwidth limit on internet ssid for example 5/1 (download and uploads) for each router (or different bandwidth for each one if it is possible) and private ssid to be unlimited.
How to set up that? I tried few thing but nothing works. When I connect them without CAPs it works, but I change settings to CAPs for easy manage (change password on internet ssid periodicly).
Thnx.
My configuration on main is
# may/05/2023 08:56:42 by RouterOS 7.8
# software id = YJM6-***
# model = RB951G-2HnD
# serial number = ***
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=Ce frequency=\
2437 name=channel1
add name=bridge-internet
add name=bridge-private
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=***
/interface wireless
set [ find default-name=wlan1 ] mode=ap-bridge ssid=MikroTik wireless-protocol=\
802.11
/caps-man datapath
add bridge=bridge-private local-forwarding=no name=datapath-private
add bridge=bridge-internet name=datapath-internet
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security-private
add authentication-types=wpa2-psk encryption=aes-ccm name=security-internet
/caps-man configuration
add channel=channel1 country="bosnia and herzegovina" datapath=datapath-private \
distance=dynamic installation=any mode=ap name=cfg-private security=\
security-private ssid=private
add channel=channel1 country="bosnia and herzegovina" datapath=\
datapath-internet distance=dynamic installation=any mode=ap name=\
cfg-internet security=security-internet ssid=internet
/caps-man interface
add channel.frequency=2437 configuration=cfg-internet configuration.mode=ap \
disabled=no mac-address=00:00:00:00:00:00 master-interface=none name=cap2 \
radio-mac=00:00:00:00:00:00 radio-name=""
add name=WAN
add name=LAN
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=aes-256 \
hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
aes-256-cbc,aes-128-cbc
add name=pool-private ranges=192.168.1.30-192.168.1.199
add name=pool-internet ranges=10.0.0.30-10.0.1.250
add address-pool=pool-private interface=bridge-private name=dhcp-private
add address-pool=pool-internet interface=bridge-internet lease-time=1h name=\
dhcp-internet
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no interface=any \
signal-range=-85..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=no interface=any \
signal-range=-120..-86 ssid-regexp=""
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg-private \
slave-configurations=cfg-internet
add bridge=bridge-private interface=ether2
add bridge=bridge-private interface=ether3
add bridge=bridge-private interface=ether4
add bridge=bridge-private interface=ether5
add bridge=bridge-private interface=wlan1
/ipv6 settings
set disable-ipv6=yes
add interface=bridge-private list=LAN
add address=192.168.1.1/24 interface=bridge-private network=192.168.1.0
add address=10.0.0.1/8 interface=bridge-internet network=10.0.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add disabled=yes interface=ether1
add address=10.0.0.0/8 dns-server=208.67.222.222,8.8.8.8,1.1.1.1 gateway=\
10.0.0.1
add address=192.168.1.0/24 dns-server=8.8.8.8,208.67.222.222,1.1.1.1,8.8.4.4 \
gateway=192.168.1.1 netmask=24
set servers=8.8.8.8
add action=accept chain=forward out-interface-list=WAN src-address=\
192.168.252.0/24
add action=accept chain=forward dst-address=192.168.252.0/24 in-interface-list=\
WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=input in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input dst-port=500,1701,4500 in-interface=ether1 \
protocol=udp
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=\
udp
add action=drop chain=input in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-port=81 in-interface=pppoe-out1 protocol=\
tcp to-addresses=192.168.1.200 to-ports=81
add action=dst-nat chain=dstnat dst-port=10000 in-interface=pppoe-out1 \
protocol=tcp to-addresses=192.168.1.200 to-ports=10000
add action=dst-nat chain=dstnat dst-port=82 in-interface=pppoe-out1 protocol=\
tcp to-addresses=192.168.1.202 to-ports=80
udp to-addresses=192.168.1.202 to-ports=80
add action=dst-nat chain=dstnat disabled=yes dst-port=83 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.1.206 to-ports=80
add action=dst-nat chain=dstnat dst-limit=1,5,dst-address/1m40s dst-port=3389 \
in-interface=pppoe-out1 limit=1,5:packet protocol=tcp to-addresses=\
192.168.1.241 to-ports=3389
add action=masquerade chain=srcnat comment="default configuration" disabled=yes \
out-interface=all-ethernet
pppoe-out1 port="" protocol=udp src-port="" to-addresses=192.168.1.206 \
to-ports=80
add action=masquerade chain=srcnat out-interface-list=WAN src-address=\
192.168.252.0/24
/ip service
set ssh disabled=yes
/system clock
set time-zone-name=Europe/Sarajevo
/system identity
set name=Router
/tool mac-server
/tool mac-server mac-winbox
