I can’t find instructions on how to mount the cAP ax on the ceiling. I was about to fix the plastic triangular fitting on the ceiling with the two screws, when I noticed a metal piece, which was marked ‘ceiling mount’ on the website. At first, it appears to fit to the plastic part, since the holes match. But the holes are way too small for the screws that supposedly have to be used to fix the access point to the ceiling.
I am wondering how this metal part is supposed to be used, if the screws don’t fit.
And, of course, I always notice this kind of things on Fridays, shortly after business hours.
My guess is that I should force the screws through the holes, maybe using a hammer, regardless of the possible damage. Correct?
