cAP AX maximum Tx just 50 % of maximum Rx
Dear forum,
I experience slower download rates than upload rates of my wireless devices via cAP AX (-> CRS326 → RB5009 → ISP): downloads are approx. 50 % slower than uploads.
The absolute speeds (240 Mbit down, 480 Mbit up) are totally acceptable, but the difference is huge and I would like to understand the reason and, if possible, resolve the delta.
From your general experience and knowledge: where and what should I look into? Are there any usual suspects?
  • Sven
Can you share what (client) devices you are using?
At what rates are the clients connected?
Can you share the settings of the cAP AX?
According to WiFi Registration:
Apple iPhone 15 Pro Max (2023) via 5GHz Tx 960.8 Mbps / Rx 960.8 Mbps
Apple MacBook Pro M1 Max (2020) via 5GHz 1201.0 Mbps / Rx 960.8 Mbps
# 2024-05-21 12:20:27 by RouterOS 7.14.3
# software id = 8C87-BNE8
# model = cAPGi-5HaxD2HaxD
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no name=bridge-og-cap \
    vlan-filtering=yes
set [ find default-name=ether1 ] comment="PoE in | Uplink"
set [ find default-name=ether2 ] comment="PoE out" poe-out=off
/interface vlan
add comment=management interface=bridge-og-cap name=vlan1-management vlan-id=\
    1
add comment=home interface=bridge-og-cap name=vlan10-home vlan-id=10
add comment=guests interface=bridge-og-cap name=vlan30-guests vlan-id=30
add name=LAN
/interface wifi datapath
add bridge=bridge-og-cap disabled=no name=datapath
/interface wifi
# managed by CAPsMAN
# mode: AP, SSID: XXX, channel: 5805/ax/eeeC
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap \
    datapath=datapath disabled=no
# mode: AP, SSID: XXX, channel: 2412/ax
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap \
add bridge=bridge-og-cap interface=ether1
add bridge=bridge-og-cap interface=ether2
add bridge=bridge-og-cap interface=wifi1
add bridge=bridge-og-cap interface=wifi2
/interface bridge vlan
add bridge=bridge-og-cap comment=management tagged=bridge-og-cap vlan-ids=1
add bridge=bridge-og-cap comment=home tagged=bridge-og-cap,ether1,ether2 \
    vlan-ids=10
add bridge=bridge-og-cap comment=guests tagged=bridge-og-cap,ether1,ether2 \
    vlan-ids=30
add interface=bridge-og-cap list=LAN
add interface=vlan1-management list=LAN
add interface=vlan10-home list=LAN
/interface wifi cap
set caps-man-addresses=10.0.0.1 certificate=request discovery-interfaces=\
    vlan1-management enabled=yes lock-to-caps-man=yes slaves-datapath=\
    datapath
/ip dhcp-client
add comment=defconf disabled=yes interface=bridge-og-cap
/system clock
/system identity
set name=OG-cAP-ax
/system leds settings
set all-leds-off=after-1h
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Connection rates look pretty good. Only remark I have on your config, don’t use VLAN ID 1 explicitly. But that has nothing to do with your findings.
How do you speedtest? If not already tried, could you use iPerf with the server running on a device connected wired?
I am using the iOS and macOS Speedtest by OOKLA apps (speedtest.net).
Wired connection gives me download ~530 Mbps and upload ~690 Mbps, both higher than expected as ISP connection is 500/500 via fiber.
