CAP AX mount distance between holes
An odd question, I know.
But I intend to buy a cAP ax ceiling mount but want to have the holes drilled before that (since a have a person here drilling some holes for installing a bunch of CAP AC (those ones I have already :slight_smile:)) I will take the opportunity to drill for the AX in advance).
But I can’t find what is the distance between the screw holes for cAP ax ceiling mount
I have looked at the mounting instructions (https://i.mt.lv/cdn/product_files/cAPaxmountinginstruction_230526.pdf) but it has no dimensions.
Can someone point me to the distance between the 2 holes?
Thank you
The plastic mounting bracket ?
3.4 cm
(yeah, I need to clean the lens…)
Awesome. Thank you for the quick reply
