CAP AX possible wifi driver issue c
Hi. I have a full mikrotik network, L009 router, feeding a HEX PoE configured as a bridge, supplying PoE and series of VLANs to 3 CAP ax units. I have 5ghz with 2 virtuals, and 2.4Ghz also with 2 virtuals. Apart for a device issue, this system works well. Its the 2.4ghz, IOT, Samsung, Fisher Paykel, Lambon Switches, Haier, K-Rain sprinkler, Dooya blinds,etc, all are fine. Its the Panasonic Wifi modules that fail. They connect, then after a period of time, one by one, they disconnect with no reason. Have turned on wifi debug log, but no help. We They fail, they are no longer in Registration or active DHCP lease. I have tried them on own vlan, I have tried only broadcasting their SSID on just one CAP ax, all fails. I have now tried with a cheap GLI net travel router, connected to L009 on Eth 8, no vlan, set up same ssid name and password, and they all work a treat. The Panasonic wifi modules may be a little dated as they noe come integral within the units but they are still being sold and used. So, apart from removing CAP Ax , or adding another wifi radio to the system, via CAP AX eth 2, my preference is to fix the problem. Any one have any ideas. ROS is latest version on all devices.
Please supply exact version, also for future purposes.
Can you supply the config as well?
/interface/wifi export
Sometimes it helps to provide an SSID (i.e. for IoT devices) on 2.4GHz radio only.
Thanks. Copy of export below. SSIDs Upolu-Pan-1 and Upolu-Pana -3 are disabled. These are virtual under IoT 2.4GHZ and IoT is only 2.4GHZ. At present IoT is using N as have been testing all sorts of variation, I prefer AX. Also, I have truied Pan SSIDs in G. I also upgrasde to ROS Ver 7.2.4 Beta 3 to see if anything in there might assist, but to no avail. Caps are running 7.23 along with HEX Poe.
add band=5ghz-ax frequency=5180 name=5GHZ::CH36 width=20mhz
add band=5ghz-ax frequency=5200 name=5GHZ::CH40 width=20mhz
add band=5ghz-ax frequency=5220 name=5GHZ::CH44 width=20mhz
add band=5ghz-ax frequency=5240 name=5GHZ::CH48 width=20mhz
add band=5ghz-ax frequency=5745 name=5GHZ::CH149 width=20mhz
add band=5ghz-ax frequency=5765 name=5GHZ::CH153 width=20mhz
add band=5ghz-ax frequency=5785 name=5GHZ::CH157 width=20mhz
add band=5ghz-ax frequency=5805 name=5GHZ::CH161 width=20mhz
add band=5ghz-ax frequency=5825 name=5GHZ::CH165 width=20mhz
add band=5ghz-ax disabled=no frequency=5180,5200,5220,5240 name=5GHZ::UNII-1 width=20mhz
add band=5ghz-ax disabled=no frequency=5745,5765,5785,5805,5825 name=5GHZ::UNII-3 width=20mhz
add band=5ghz-ax disabled=no frequency=5180,5200,5220,5240,5745,5765,5785,5805,5825 name=5GHZ::NON-DFS width=20mhz
add band=2ghz-ax frequency=2412 name=2GHZ::CH1 width=20mhz
add band=2ghz-ax frequency=2437 name=2GHZ::CH6 width=20mhz
add band=2ghz-ax frequency=2462 name=2GHZ::CH11 width=20mhz
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=2GHZ::AUTO width=20mhz
/interface wifi datapath
add disabled=no name=Path-Guest vlan-id=30
add disabled=no name=Path-IoT vlan-id=40
add disabled=no name=Path-Owner vlan-id=20
add disabled=no name=Path-Admin vlan-id=10
add disabled=no name=Path-vlan50 vlan-id=50
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=sec-Guest
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-Owner
add authentication-types=wpa2-psk disabled=no name=sec-IoT
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=sec-Admin
add authentication-types=wpa2-psk disable-pmkid=no disabled=no name=sec-Vlan-50
/interface wifi configuration
add antenna-gain=0 channel=5GHZ::NON-DFS channel.width=20/40/80mhz country=Australia datapath=Path-Admin disabled=no mode=ap name=cfg5-Admin security=sec-Admin security.ft=yes .ft-over-ds=yes ssid=UPOLU-Admin steering.rrm=yes
add channel=2GHZ::AUTO channel.band=2ghz-n .width=20mhz country=Australia datapath=Path-IoT disabled=no max-clients=100 mode=ap multicast-enhance=disabled name=cfg-2-IoT security=sec-IoT security.ft=no ssid=Upolu-IoT
add country=Australia datapath=Path-Guest disabled=no mode=ap name=cfg-5-Guest security=sec-Guest ssid=Upolu-Guest
add country=Australia datapath=Path-Owner disabled=no mode=ap name=cfg-5-Owner security=sec-Owner security.ft=yes .ft-over-ds=yes ssid=Upolu steering.rrm=yes
add channel.band=2ghz-n .width=20mhz datapath=Path-vlan50 datapath.vlan-id=50 disabled=no max-clients=10 mode=ap multicast-enhance=disabled name=cfg-2-Sec security=sec-Vlan-50 ssid=Upolu-Sec
add channel.band=2ghz-g .width=20mhz datapath=Path-vlan50 datapath.vlan-id=50 disabled=no max-clients=10 mode=ap multicast-enhance=disabled name=cfg-2-Pana-1 security=sec-Vlan-50 ssid=Upolu-Pana-1
add channel.band=2ghz-g .width=20mhz datapath=Path-vlan50 datapath.vlan-id=50 disabled=no max-clients=10 mode=ap multicast-enhance=disabled name=cfg-Pana-2 security=sec-Vlan-50 ssid=Upolu-Pana-2
add channel.band=2ghz-g .width=20mhz datapath=Path-vlan50 datapath.vlan-id=50 disabled=no max-clients=10 mode=ap multicast-enhance=disabled name=cfg2-Pana-3 security=sec-Vlan-50 ssid=Upolu-Pana-3
/interface wifi
operated by CAP F4:1E:57:B8:56:97%vlan10-Admin, traffic processing on CAP
add configuration=cfg-2-IoT disabled=no mtu=1500 name=cap1-wifi2-IoT radio-mac=F4:1E:57:B8:56:9A
add configuration=cfg-2-Pana-1 configuration.mode=ap mac-address=F6:1E:57:B8:56:9C master-interface=cap1-wifi2-IoT mtu=1500 name=cap1-wifi2-Pana-1
add configuration=cfg-Pana-2 mac-address=F6:1E:57:B8:56:9B master-interface=cap1-wifi2-IoT mtu=1500 name=cap1-wifi2-Pana-2
add configuration=cfg2-Pana-3 mac-address=F6:1E:57:B8:56:9D master-interface=cap1-wifi2-IoT mtu=1500 name=cap1-wifi2-Pana-3
add configuration=cfg-2-Sec mac-address=F6:1E:57:B8:56:9E master-interface=cap1-wifi2-IoT mtu=1500 name=cap1-wifi2-sec
operated by CAP F4:1E:57:B8:59:58%vlan10-Admin, traffic processing on CAP
add configuration=cfg-2-IoT disabled=no mtu=1500 name=cap2-wifi4-IoT radio-mac=F4:1E:57:B8:59:5B
add configuration=cfg-2-Pana-1 mac-address=F6:1E:57:B8:59:5D master-interface=cap2-wifi4-IoT mtu=1500 name=cap2-wifi4-Pana-1
add configuration=cfg-Pana-2 disabled=no mac-address=F6:1E:57:B8:59:5C master-interface=cap2-wifi4-IoT mtu=1500 name=cap2-wifi4-Pana-2
add configuration=cfg2-Pana-3 mac-address=F6:1E:57:B8:59:5E master-interface=cap2-wifi4-IoT mtu=1500 name=cap2-wifi4-Pana-3
add configuration=cfg-2-Sec mac-address=F6:1E:57:B8:59:5F master-interface=cap2-wifi4-IoT mtu=1500 name=cap2-wifi4-Sec
operated by CAP 04:F4:1C:7D:37:F7%vlan10-Admin, traffic processing on CAP
add configuration=cfg-2-IoT disabled=no mtu=1500 name=cap3-wifi6-IoT radio-mac=04:F4:1C:7D:37:FA
add configuration=cfg-Pana-2 mac-address=06:F4:1C:7D:37:FB master-interface=cap3-wifi6-IoT mtu=1500 name=cap3-wifi6-Pana-2
add configuration=cfg2-Pana-3 mac-address=06:F4:1C:7D:37:FD master-interface=cap3-wifi6-IoT mtu=1500 name=cap3-wifi6-Pana-3
add configuration=cfg-2-Pana-1 mac-address=06:F4:1C:7D:37:FC master-interface=cap3-wifi6-IoT mtu=1500 name=cap3-wifi6-Pans-1
add configuration=cfg-2-Sec mac-address=06:F4:1C:7D:37:FE master-interface=cap3-wifi6-IoT mtu=1500 name=cap3-wifi6-Sec
/interface wifi access-list
add action=accept
/interface wifi cap
set caps-man-addresses=172.20.10.1 certificate=request discovery-interfaces=LAN-BRIDGE enabled=yes
/interface wifi capsman
set ca-certificate=auto certificate=auto enabled=yes interfaces=LAN-BRIDGE,vlan10-Admin package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg5-Admin slave-configurations=cfg-5-Owner,cfg-5-Guest supported-bands=5ghz-ax
add action=create-enabled disabled=no master-configuration=cfg-2-IoT slave-configurations=cfg-Pana-2,cfg-2-Pana-1,cfg2-Pana-3,cfg-2-Sec supported-bands=2ghz-n
