I just unpacked my new cAP ax and wanted to configure it and connect to my existing capsman managed wifi network. When i log into the device there is no CAP settings in Wireless menu. How do I manage this device with my capsman?
Also, I have upgraded ROS from 7.7 to 7.9 on a second cap ax, and now that cap ax does not have wlan interfaces.
all AX devices need “wifiwave2” package, which you probably did not upload, when doing manual upgrade. I suggest using “check for updates” menu to avoid such mistakes in future
AX devices also have new CAPsMAN, and CAP in other menu under wireless → Remote CAP tab.
Just to make sure that I got things correctly: I cannot provision cap ax devices from “old capsman” and I cannot provision cap ac from wifiwave2 capsman? Can cap ax use standard wireless package insted of wifiwave2? Is it possible to add cap ax to an existing wifi network that is running on capsman with a lot of cap ac devices?
How can you handle a CAP AC device with the “new” CAPsMAN, e.g. the wifiwave2 based one?
My understanding is that wifiwave2 package is needed on CAPsMAN client and CAP AC is not supported.
No. But really. You will need a second controller if you want the AX cap to be capsman controlled as well.
Until, someday maybe, they integrate the two into one.
