hAP ax3 hAP ax2 hAP ax working maybe not perect but good
hAP ax3
# 2024-04-17 16:41:05 by RouterOS 7.14.2
# software id = 3K51-Q0D9
# model = C53UiG+5HPaxD2HPaxD
# serial number = H..............
add name=caps_mgmt-LAN priority=0x7999
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN
set [ find default-name=ether3 ] name=ether3-LAN
set [ find default-name=ether4 ] name=ether4-LAN
set [ find default-name=ether5 ] name=ether5-LAN
/interface vlan
add disabled=yes interface=caps_mgmt-LAN name=vlan-10-Home vlan-id=10
add disabled=yes interface=caps_mgmt-LAN name=vlan-20-Guest vlan-id=20
add name=LAN
add name=WAN
/interface wifi channel
add band=2ghz-n disabled=no frequency=2412,2437,2462 name=2G-N width=\
20/40mhz-Ce
add band=5ghz-ac disabled=no frequency=5180 name=5G-AC width=20/40mhz-Ce
add band=5ghz-ax disabled=no frequency=5180 name=5G-AX width=20/40mhz-Ce
add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=2G-AX width=\
20/40mhz-Ce
/interface wifi datapath
add bridge=caps_mgmt-LAN disabled=no interface-list=LAN name=datapath1
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no group-encryption=ccmp \
group-key-update=1h name=sec2G
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no \
group-encryption=ccmp group-key-update=5m management-encryption=cmac \
name=sec5G
/interface wifi configuration
add channel=2G-AX country=Poland datapath=datapath1 disabled=no mode=ap name=\
2G-AX security=sec2G ssid="Wifi Biuro 2G AX Cap2"
add channel=5G-AX country=Poland datapath=datapath1 datapath.bridge=\
caps_mgmt-LAN disabled=no mode=ap name=5G-AX security=sec5G security.ft=\
yes .ft-over-ds=yes ssid="Wifi Biuro 5G AX Cap2"
add channel=2G-N country=Poland datapath=datapath1 disabled=no mode=ap name=\
2G-N security=sec2G ssid="Wifi Biuro 2G N Cap2"
add channel=5G-AC country=Poland datapath=datapath1 datapath.bridge=\
caps_mgmt-LAN disabled=no mode=ap name=5G-AC security=sec5G security.ft=\
no ssid="Wifi Biuro 5G AC Cap2"
/interface wifi
add channel=2G-AX configuration=2G-AX configuration.mode=ap datapath=\
datapath1 disabled=no name=cap-wifi_2G-cAP_AX radio-mac=78:9A:18:C9:B0:77 \
security=sec2G
datapath1 disabled=no name=cap-wifi_2G-hAP_ax2 radio-mac=\
48:A9:8A:CD:34:E2 security=sec2G
add channel=5G-AC channel.frequency=5180 configuration=5G-AX \
configuration.mode=ap datapath=datapath1 disabled=no name=\
cap-wifi_5G-cAP_AX radio-mac=78:9A:18:C9:B0:76 security=sec5G \
security.ft=no
add channel=5G-AC channel.band=5ghz-ac .frequency=5180 configuration=5G-AC \
cap-wifi_5G-hAP_ax2 radio-mac=48:A9:8A:CD:34:E1 security=sec5G
set [ find default-name=wifi2 ] channel=2G-AX configuration=2G-AX \
configuration.manager=local .mode=ap datapath=datapath1 \
datapath.interface-list=LAN disabled=no name=wifi_2G-hAP_ax3 security=\
sec2G
set [ find default-name=wifi1 ] channel=5G-AC channel.band=5ghz-ac \
configuration=5G-AX configuration.manager=local .mode=ap datapath=\
datapath1 disabled=no name=wifi_5G-hAP_ax3 security=sec5G \
security.authentication-types=wpa3-psk
/interface wifi steering
add disabled=no name=steering2 neighbor-group="dynamic-wifi 5ghz-a80d8a44" \
rrm=yes wnm=yes
add disabled=no name=steering1 neighbor-group="dynamic-wifi 2ghz-a80d8a44" \
rrm=yes wnm=yes
add name=dhcp-LAN ranges=192.168.66.2-192.168.66.200
add name=dhcpl-WIFI ranges=192.168.77.2-192.168.77.200
add address-pool=dhcp-LAN interface=caps_mgmt-LAN lease-time=1d name=\
dhcp1_LAN
add bridge=caps_mgmt-LAN interface=ether2-LAN
add bridge=caps_mgmt-LAN interface=ether3-LAN
add bridge=caps_mgmt-LAN interface=ether4-LAN
add bridge=caps_mgmt-LAN interface=ether5-LAN
add bridge=caps_mgmt-LAN interface=wifi_5G-hAP_ax3
add bridge=caps_mgmt-LAN fast-leave=yes interface=wifi_2G-hAP_ax3
/ipv6 settings
set accept-router-advertisements=yes
/interface bridge vlan
add bridge=caps_mgmt-LAN tagged=\
caps_mgmt-LAN,ether2-LAN,ether3-LAN,ether4-LAN,ether5-LAN vlan-ids=10
caps_mgmt-LAN,ether2-LAN,ether3-LAN,ether4-LAN,ether5-LAN vlan-ids=20
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
LAN wan-interface-list=WAN
add interface=ether1-WAN list=WAN
add interface=caps_mgmt-LAN list=LAN
add interface=ether2-LAN list=LAN
add interface=ether3-LAN list=LAN
add interface=ether4-LAN list=LAN
add interface=ether5-LAN list=LAN
add interface=wifi_2G-hAP_ax3 list=LAN
add interface=lo list=LAN
add interface=wifi_5G-hAP_ax3 list=LAN
/interface wifi cap
set caps-man-addresses=192.168.66.1 certificate=request discovery-interfaces=\
caps_mgmt-LAN enabled=yes lock-to-caps-man=yes slaves-datapath=datapath1 \
slaves-static=no
/interface wifi capsman
set ca-certificate=WiFi-CAPsMAN-CA-48A98AEACE4D enabled=yes interfaces=\
caps_mgmt-LAN package-path="" require-peer-certificate=yes \
upgrade-policy=none
/interface wifi provisioning
add action=create-enabled disabled=no master-configuration=5G-AX name-format=\
5G-%| supported-bands=5ghz-ax
add action=create-enabled disabled=no master-configuration=2G-AX name-format=\
2G-%| supported-bands=2ghz-ax
add action=create-enabled disabled=no master-configuration=5G-AC name-format=\
5G-%| supported-bands=5ghz-ac
add action=create-enabled disabled=no master-configuration=2G-N name-format=\
2G-%| supported-bands=2ghz-n
add address=192.168.66.1/24 interface=caps_mgmt-LAN network=192.168.66.0
add address=127.0.0.1 interface=lo network=127.0.0.1
add address=192.168.77.1/24 interface=*11 network=192.168.77.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.66.169 client-id=1:30:c9:ab:5:58:61 mac-address=\
30:C9:AB:05:58:61 server=dhcp1_LAN
add address=192.168.66.167 client-id=1:c8:d7:78:a4:79:73 mac-address=\
C8:D7:78:A4:79:73 server=dhcp1_LAN
add address=192.168.66.166 mac-address=C4:77:AF:27:3F:CF server=dhcp1_LAN
add address=192.168.66.165 client-id=1:9c:3e:53:8:5c:69 mac-address=\
9C:3E:53:08:5C:69 server=dhcp1_LAN
add address=192.168.66.181 client-id=1:64:95:6c:3c:f2:2c mac-address=\
64:95:6C:3C:F2:2C server=dhcp1_LAN
add address=192.168.66.178 mac-address=C4:77:AF:3F:52:DE server=dhcp1_LAN
add address=192.168.66.0/24 dns-server=192.168.66.1 gateway=192.168.66.1 \
netmask=24
add address=192.168.77.0/24 dns-server=192.168.66.1 gateway=192.168.77.1 \
netmask=24
set allow-remote-requests=yes servers=192.168.66.1,192.168.73.10
add action=reject chain=forward disabled=yes dst-address-list=OfficeWLAN \
reject-with=icmp-network-unreachable src-address-list=Guest-WLAN
add action=reject chain=input disabled=yes dst-address-list=OfficeWLAN \
reject-with=icmp-host-unreachable src-address-list=Guest-WLAN
add action=reject chain=forward disabled=yes dst-address-list=FB-HomeLan \
add action=reject chain=input disabled=yes dst-address-list=FB-HomeLan \
add action=reject chain=forward disabled=yes dst-address-list=\
Guest-WLAN-Clients reject-with=icmp-host-prohibited src-address-list=\
Guest-WLAN
add action=accept chain=input dst-port=5246,5247 protocol=udp
add action=accept chain=input dst-address=127.0.0.1
add action=accept chain=input dst-address=127.0.0.1 port=5246,5247 protocol=\
udp src-address=127.0.0.1
add action=masquerade chain=srcnat out-interface=ether1-WAN
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=CAPsMan2Controller
/system note
set show-at-login=no
/system package update
set channel=testing
/tool romon
set enabled=yes
hAP ax2
# 2024-04-17 16:41:43 by RouterOS 7.14.2
# software id = PTQA-B3Z5
# model = C52iG-5HaxD2HaxD
add admin-mac=48:A9:8A:CD:34:DD auto-mac=no ingress-filtering=no name=\
caps_mgmt-LAN priority=0x7999 vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-TRUNK
/interface vlan
add name=LAN
add name=WAN
/interface wifi aaa
add disabled=no name=aaa1
add band=2ghz-n disabled=yes frequency=2716,2737,2762 name=channelAC width=\
20mhz
add bridge=caps_mgmt-LAN disabled=yes name=wlan-AX-Office vlan-id=10
add bridge=caps_mgmt-LAN client-isolation=yes disabled=yes name=wlan-AX-Guest \
vlan-id=20
add bridge=caps_mgmt-LAN disabled=yes name=wlan-AC-Office
add bridge=caps_mgmt-LAN client-isolation=yes disabled=yes name=wlan-AC-Guest
add bridge=caps_mgmt-LAN disabled=no name=datapath1
/interface wifi
# managed by CAPsMAN
# mode: AP, SSID: Wifi Biuro 5G AC Cap2, channel: 5180/ac/Ce
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap \
datapath=datapath1 disabled=no name=wifi1-hAP_a2 security.ft=yes
# mode: AP, SSID: Wifi Biuro 2G AX Cap2, channel: 2437/ax/Ce
set [ find default-name=wifi2 ] channel.frequency=2716,2737,2762 \
configuration.manager=capsman .mode=ap datapath=datapath1 disabled=no \
name=wifi2-hAP_a2 security.ft=yes
add authentication-types=wpa2-psk disabled=yes encryption=ccmp ft=yes \
ft-over-ds=yes name=Sec-Office
add authentication-types=wpa2-psk disabled=yes encryption=ccmp name=Sec-Guest
add authentication-types=wpa2-psk disabled=yes ft=yes name=sec1
add channel.skip-dfs-channels=all country=Germany datapath=wlan-AX-Office \
disabled=yes mode=ap name=cfg-AX-Office security=Sec-Office security.ft=\
yes .ft-over-ds=yes ssid=MT-Office
add channel.skip-dfs-channels=all country=Germany datapath=wlan-AX-Guest \
disabled=yes mode=ap name=cfg-AX-Guest security=Sec-Guest security.ft=yes \
.ft-over-ds=yes ssid=MT-Guest
add channel.skip-dfs-channels=all country=Poland datapath=wlan-AC-Office \
disabled=yes mode=ap name=cfg-AC-Office security=Sec-Office security.ft=\
add channel.skip-dfs-channels=all country=Germany datapath=wlan-AC-Guest \
disabled=yes mode=ap name=cfg-AC-Guest security=Sec-Guest security.ft=yes \
add name=dhcp_pool0-vlan10 ranges=10.10.10.20-10.10.10.200
add name=dhcp_pool1-vlan20 ranges=20.20.20.20-20.20.20.200
add address-pool=dhcp_pool0-vlan10 disabled=yes interface=vlan-10-Home \
lease-time=3d name=dhcp-vlan10
add address-pool=dhcp_pool1-vlan20 disabled=yes interface=vlan-20-Guest \
lease-time=8h name=dhcp-vlan20
/queue type
add kind=pcq name=PCQ-Download-40Mbit pcq-classifier=dst-address pcq-rate=41M
add kind=pcq name=PCQ-Upload-15Mbit pcq-classifier=src-address pcq-rate=15M
add kind=pcq name=PCQ-Download-25Mbit pcq-classifier=dst-address pcq-rate=25M
add kind=pcq name=PCQ-Upload-05Mbit pcq-classifier=src-address pcq-rate=6M
/queue simple
add max-limit=30M/75M name=queue-GuestWLan queue=\
PCQ-Upload-05Mbit/PCQ-Download-25Mbit target=vlan-20-Guest total-queue=\
PCQ-Download-25Mbit
add max-limit=35M/85M name=queue-WLan priority=7/7 queue=\
PCQ-Upload-15Mbit/PCQ-Download-40Mbit target=vlan-10-Home total-queue=\
PCQ-Download-40Mbit
add bridge=caps_mgmt-LAN interface=wifi1-hAP_a2
add bridge=caps_mgmt-LAN interface=wifi2-hAP_a2
add bridge=caps_mgmt-LAN interface=ether1-TRUNK
/ipv6 settings
add interface=ether1-TRUNK list=WAN
add interface=wifi1-hAP_a2 list=LAN
add interface=wifi2-hAP_a2 list=LAN
/interface wifi cap
caps_mgmt-LAN enabled=yes lock-to-caps-man=no slaves-datapath=datapath1
set interfaces="" package-path=/capsman require-peer-certificate=no \
upgrade-policy=none
add action=create-dynamic-enabled comment="default 2GHz AX" disabled=yes \
master-configuration=cfg-AX-Office name-format="2GHz ax wifi-%I" \
slave-configurations=cfg-AX-Guest supported-bands=2ghz-ax
add action=create-dynamic-enabled comment="default 5GHz AX" disabled=yes \
master-configuration=cfg-AX-Office name-format="5GHz ax wifi-%I" \
slave-configurations=cfg-AX-Guest supported-bands=5ghz-ax
add action=create-dynamic-enabled comment="default 2GHz N (none AX)" \
disabled=yes master-configuration=cfg-AC-Office name-format=\
"hAPac 2GHz wifi-%C" slave-configurations=cfg-AC-Guest supported-bands=\
2ghz-n
add action=create-dynamic-enabled comment="default 5GHz ac (none AX)" \
"hAPac 5GHz wifi-%C" slave-configurations=cfg-AC-Guest supported-bands=\
5ghz-ac
add address=10.10.10.1/24 disabled=yes interface=vlan-10-Home network=\
10.10.10.0
add address=20.20.20.1/24 disabled=yes interface=vlan-20-Guest network=\
20.20.20.0
/ip dhcp-client
/ip firewall address-list
add address=20.20.20.0/24 list=Guest-WLAN
add address=10.10.10.0/24 list=OfficeWLAN
add address=192.168.178.2-192.168.178.255 list=FB-HomeLan
add address=20.20.20.20-20.20.20.255 list=Guest-WLAN-Clients
add action=reject chain=forward dst-address-list=OfficeWLAN reject-with=\
add action=reject chain=input dst-address-list=OfficeWLAN reject-with=\
add action=reject chain=forward dst-address-list=FB-HomeLan reject-with=\
add action=reject chain=input dst-address-list=FB-HomeLan reject-with=\
add action=reject chain=forward dst-address-list=Guest-WLAN-Clients \
reject-with=icmp-host-prohibited src-address-list=Guest-WLAN
add action=reject chain=input dst-address-list=Guest-WLAN-Clients \
add action=reject chain=forward reject-with=icmp-host-prohibited
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark=guest-conn \
passthrough=yes src-address-list=Guest-WLAN
# in/out-interface matcher not possible when interface (ether1-TRUNK) is slave - use master instead (caps_mgmt-LAN)
add action=masquerade chain=srcnat out-interface=ether1-TRUNK
/system clock
/system identity
set name=Mikrotik_hAP_ax2
/system note
/tool romon
set enabled=yes
hAP ax
# 2024-04-17 16:42:12 by RouterOS 7.14.2
# software id = EI3M-9MTI
# model = cAPGi-5HaxD2HaxD
add admin-mac=78:9A:18:C9:B0:74 auto-mac=no name=caps_mgmt-LAN
/interface wifi
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap \
disabled=no name=wifi2-cAP_AX security.ft=yes
add bridge=caps_mgmt-LAN comment=defconf disabled=no name=capdp
/interface wifi
# mode: AP, SSID: Wifi Biuro 5G AX Cap2, channel: 5180/ac/Ce
datapath=capdp disabled=no name=wifi1-cAP_AX security.ft=no
add bridge=caps_mgmt-LAN interface=wifi1-cAP_AX
add bridge=caps_mgmt-LAN interface=wifi2-cAP_AX
set udp-timeout=10s
/interface wifi cap
set ca-certificate=auto interfaces=wifi1-cAP_AX,wifi2-cAP_AX package-path="" \
require-peer-certificate=no upgrade-policy=none
/ip dhcp-client
set servers=195.3.203.3,195.66.73.10
/system clock
/system identity
set name=MikroTik_cAP_ax
/system note
hAP ac3 can’t conect to CAPsMAN on hAP ax3
hAP ac3
# 2024-04-17 16:43:53 by RouterOS 7.14.2
# software id = WBTJ-LEM6
# model = RBD53iG-5HacD2HnD
# serial number = D.........
add name=WAN
add name=LAN
add band=2ghz-n disabled=no frequency=2412,2437,2462 name=channel2G width=\
20mhz
add band=5ghz-ac disabled=no frequency=5180 name=channel5G width=20mhz
add authentication-types=wpa2-psk disabled=no group-encryption=ccmp name=sec1
add channel=channel2G country=Poland datapath=datapath1 disabled=no mode=ap \
name=wifi_haCP_2G security=sec1 ssid=Mikrotik_2G_D
add channel=channel5G country=Poland datapath=datapath1 disabled=no mode=ap \
name=wifi_haCP_5G security=sec1 ssid=Mikrotik_5G_D
/interface wifi
# no connection to CAPsMAN
add channel=channel2G channel.frequency=2412,2437,2462 configuration=\
wifi_haCP_2G configuration.manager=capsman .mode=ap datapath=datapath1 \
disabled=no name=wifi1-haP_ac3_2G radio-mac=48:8F:5A:AA:3B:0C security=\
sec1
add channel.frequency=5180 configuration=wifi_haCP_5G configuration.manager=\
capsman .mode=ap disabled=no name=wifi2-haP_ac3_5G radio-mac=\
48:8F:5A:AA:3B:0D security.ft=yes
add name=dhcp_pool0 ranges=192.168.66.1-192.168.66.181
add bridge=caps_mgmt-LAN interface=wifi1-haP_ac3_2G
add bridge=caps_mgmt-LAN interface=wifi2-haP_ac3_5G
add bridge=caps_mgmt-LAN interface=ether1-WAN
add interface=wifi2-haP_ac3_5G list=LAN
add interface=wifi1-haP_ac3_2G list=LAN
/interface wifi cap
set caps-man-addresses=192.168.66.1 certificate=WiFi-CAPsMAN-488F5AAA3B07 \
discovery-interfaces=caps_mgmt-LAN enabled=yes slaves-static=yes
set interfaces=caps_mgmt-LAN package-path="" require-peer-certificate=no \
upgrade-policy=none
add action=create-enabled disabled=no master-configuration=wifi_haCP_2G \
add action=create-enabled disabled=no master-configuration=wifi_haCP_5G \
/ip dhcp-client
add action=masquerade chain=srcnat out-interface=caps_mgmt-LAN
/system clock
/system identity
set name=MikroTik_D
/system note
