Cap, CAPsMAN, WEP
Hi guys.
I wanna set my mikrotiks to cap-mode.
It is for big depot building with many mobile terminals (mototola,symbol) and I want try roaming (between APs) with CAP function.
BUT, I have problem.
These little terminals are set from supplier to use WEP, 104bit static key wifi security and I dont known how to configure on CAPsMAN configuration profile.
On standard wifi interface is there no problem. On CAPsMAN I dont see it…
Please, can someone help me ?
Thanks folks
up up
CAPsMAN doesn’t support WEP as it is considered insecure.
Roaming will also work with regular APs that are bridged within the same switched network.
:frowning:
I’m so sorry, I will miss that function.
It is there any chance to implement this in future ? I mean WEB static keys to CAPs ?
