please help with the setup, I want to connect extra 2 points, but not the cable, but through wifi, what settings should I run on points? the search was not given the right information, the controller is configured, everything works fine via cable, but there is the difficulty of pulling additional cables, so if you can explain how to connect the dots via a wireless network
