cAP Gi-5acD2nD getting Too Hot
Iam having too many disconnects on a network that I have setup on a customer’s premises.
I’ve got 5 cAP Gi-5acD2nD, one per floor running in AP mode, same ssid different frequencies. All Ethernet are bridged on the same bridge that the wifi ports are.
I have 3 SSID’s running per AP, but the clients are connecting on the TESTING-Guest SSID (the 5ghz band is not been used for the users)
The problem is that the customer is complaining for multiple disconnects and I’ve seen the client loosing full connectivity and even unable to find the AP for a few seconds.
I got the same setup with different Mikrotik hardware on other customers without fail.
I’ve tried WDS, WDS mesh with same results.
I believe that the devices are getting too hot to handle by hand, but iam getting nothing out of /system health get temperature.
On the log windows other than the usual disconnect message (disconnected extensive data loss). Iam getting nothing else.
Does any one out there had temperature problems with this hardware?
Iam running version 6.42.5 and here is the relevant config:
/export compact
# jul/03/2018 09:41:01 by RouterOS 6.42.5
#<br/>
# model = RouterBOARD cAP Gi-5acD2nD
/interface bridge<br/>
add igmp-snooping=yes name=BrDevices
add fast-forward=no name=BrGuests
add igmp-snooping=yes name=BrMain
/interface vlan
add interface=BrMain name=VlanDevices vlan-id=104
add interface=BrMain name=VlanGuests vlan-id=102
add interface=BrMain name=VlanMGMT vlan-id=10
add interface=BrMain name=VlanTESTING vlan-id=101
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=TESTING-Guests \
    supplicant-identity="" wpa2-pre-shared-key=test1
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=TESTING-Users \
    supplicant-identity="" wpa2-pre-shared-key=test2
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=TESTING-Devices \
    supplicant-identity="" wpa2-pre-shared-key=test3
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5,6,7 band=2ghz-g/n country=greece disabled=no distance=\
    indoors frequency=2437 frequency-mode=regulatory-domain hw-protection-mode=cts-to-self hw-retries=4 mode=\
    ap-bridge multicast-helper=full name=Imiorofos-2.4G-Users radio-name=Ap-Imiorofos security-profile=TESTING-Users \
    ssid=TESTING tx-power=10 tx-power-mode=all-rates-fixed wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-Ceee disabled=no distance=indoors \
    frequency=5260 frequency-mode=superchannel mode=ap-bridge multicast-helper=full name=Imiorofos-5Ghz radio-name=\
    Imiorofos-5Ghz security-profile=TESTING-Devices ssid=TESTING-S tx-power=12 tx-power-mode=all-rates-fixed wps-mode=\
    disabled
add disabled=no keepalive-frames=disabled mac-address=CE:2D:E0:02:C3:E2 master-interface=Imiorofos-2.4G-Users \
    multicast-buffering=disabled multicast-helper=full name=Imiorofos-2.4-Devices security-profile=TESTING-Devices \
    ssid=TESTING-S wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=CE:2D:E0:0B:82:7E master-interface=Imiorofos-2.4G-Users \
    multicast-buffering=disabled multicast-helper=full name=Imiorofos-2.4G-Guests security-profile=TESTING-Guests \
    ssid=TESTING-Guests wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/ip hotspot profile
/port
set 0 name=serial0
add bridge=BrMain interface=ether1
add bridge=BrGuests interface=VlanGuests
add bridge=BrGuests interface=Imiorofos-2.4G-Guests
add bridge=BrDevices interface=VlanDevices
add bridge=BrDevices interface=Imiorofos-2.4-Devices
/interface wireless access-list
add interface=Imiorofos-2.4-Devices mac-address=80:CE:62:F3:61:73 vlan-mode=no-tag
add disabled=yes signal-range=-70..120 vlan-mode=no-tag
/interface wireless cap
set bridge=BrMain certificate=request discovery-interfaces=VlanMGMT interfaces=Imiorofos-2.4G-Users,Imiorofos-5Ghz \
    static-virtual=yes
add address=172.16.25.14/24 interface=VlanMGMT network=172.16.25.0
add distance=1 gateway=172.16.25.1
/ip upnp interfaces
add type=internal
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Athens
/system identity
set name=Imiorofos
/system routerboard settings
set silent-boot=no
