cap keeps disconnecting
Anyone else having issues with cap disconnecting from manager?
I have 2 running fine but the 3rd one (on the same segment) keeps disconnecting from caps manager.
23:36:47 caps,info [::ffff:172.21.1.10:56706,Dead,[D4:CA:6D:B3:7D:BF]] disconnected
23:36:47 caps,info [::ffff:172.21.1.10:41834,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:37:17 caps,info [::ffff:172.21.1.10:41834,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:37:20 caps,info [::ffff:172.21.1.10:45746,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:37:50 caps,info [::ffff:172.21.1.10:45746,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:37:53 caps,info [::ffff:172.21.1.10:44437,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:38:23 caps,info [::ffff:172.21.1.10:44437,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:38:25 caps,info [::ffff:172.21.1.10:33340,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:38:55 caps,info [::ffff:172.21.1.10:33340,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:39:06 caps,info [::ffff:172.21.1.10:40362,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:39:36 caps,info [::ffff:172.21.1.10:40362,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:39:39 caps,info [::ffff:172.21.1.10:34872,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:40:09 caps,info [::ffff:172.21.1.10:34872,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:40:11 caps,info [::ffff:172.21.1.10:57956,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:40:41 caps,info [::ffff:172.21.1.10:57956,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:40:44 caps,info [::ffff:172.21.1.10:57085,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:41:14 caps,info [::ffff:172.21.1.10:57085,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:41:20 caps,info [::ffff:172.21.1.10:51355,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:41:51 caps,info [::ffff:172.21.1.10:51355,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:41:53 caps,info [::ffff:172.21.1.10:48039,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:42:23 caps,info [::ffff:172.21.1.10:48039,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:42:26 caps,info [::ffff:172.21.1.10:60180,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:42:57 caps,info [::ffff:172.21.1.10:60180,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:43:00 caps,info [::ffff:172.21.1.10:57976,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:43:30 caps,info [::ffff:172.21.1.10:57976,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:43:34 caps,info [::ffff:172.21.1.10:52199,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:44:04 caps,info [::ffff:172.21.1.10:52199,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:44:06 caps,info [::ffff:172.21.1.10:56188,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:44:36 caps,info [::ffff:172.21.1.10:56188,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:44:38 caps,info [::ffff:172.21.1.10:45296,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:44:39 system,info log rule removed by admin
23:44:40 system,info log rule removed by admin
23:44:44 system,info log rule added by admin
23:45:06 caps,debug [::ffff:172.21.1.10:48884,Idle] Idle->DtlsSetup
23:45:08 caps,debug [::ffff:172.21.1.10:45296,DataCheck,[D4:CA:6D:B3:7D:BF]] DataCheck->DtlsTeardown
23:45:08 caps,info [::ffff:172.21.1.10:45296,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:45:08 caps,debug [::ffff:172.21.1.10:45296,DtlsTeardown] DtlsTeardown->Dead
23:45:09 caps,debug [::ffff:172.21.1.10:48884,DtlsSetup] DtlsSetup->Join
23:45:10 caps,info [::ffff:172.21.1.10:48884,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:45:10 caps,debug [::ffff:172.21.1.10:48884,Join,[D4:CA:6D:B3:7D:BF]] Join->Configure
23:45:10 caps,debug [::ffff:172.21.1.10:48884,Configure,[D4:CA:6D:B3:7D:BF]] Configure->DataCheck
23:45:38 caps,debug [::ffff:172.21.1.10:36216,Idle] Idle->DtlsSetup
23:45:40 caps,debug [::ffff:172.21.1.10:48884,DataCheck,[D4:CA:6D:B3:7D:BF]] DataCheck->DtlsTeardown
23:45:40 caps,info [::ffff:172.21.1.10:48884,DtlsTeardown,[D4:CA:6D:B3:7D:BF]] disconnected
23:45:40 caps,debug [::ffff:172.21.1.10:48884,DtlsTeardown] DtlsTeardown->Dead
23:45:41 caps,debug [::ffff:172.21.1.10:36216,DtlsSetup] DtlsSetup->Join
23:45:42 caps,info [::ffff:172.21.1.10:36216,Join,[D4:CA:6D:B3:7D:BF]] joined, provides radio(s): D4:CA:6D:B3:7D:BF
23:45:42 caps,debug [::ffff:172.21.1.10:36216,Join,[D4:CA:6D:B3:7D:BF]] Join->Configure
23:45:42 caps,debug [::ffff:172.21.1.10:36216,Configure,[D4:CA:6D:B3:7D:BF]] Configure->DataCheck
ping is 42ms average with 0% packet loss. Its a routed network and they are communicating directly with the IP (no DNS)
i have the same problem! today i will open a ticket to mikrotik.
the problem is the same with ROS 6.12 and with ROS 6.13rc14
the problem (for me) is about ROS on x86. with the CAPmanager installed on mipsbe works fine!
Any certificates involved?
Does the CAPsMAN provide a certificate?
If so, make sure the CAPsMAN’s CA cert is also present on the CAPs.
Cheers
-Chris
No Certs involved.
Anyway, given up on caps till html5 ios bug is sorted
This problem is fixed in new RouterOS v6.13rc test build, please contact support@mikrotik.com to access the development version of the CAPsMAN to test it out.
Thanks, thats the plan. However I’m going to wait a while, ROS6.12 forum post is 5 pages long, not about to start installing RC stuff just yet :wink:
