When taking a look at the hardware, I didn’t see the typical components I expected to see for 802.3af/at PoE support (negotiation chip, transformer), so I was curious how can it support “the real POE”.
When cAP lite was connected to 802.3af/at switch, it did not power on, so I assume this is a mistake in the product description? Or am I missing something and it should be working?
According to spec it supports 802.3af/at but it cannot be ruled out that an earlier hardware revision does not (and supports only passive PoE).
Of course you can still power it via the ethernet cable using the supplied PoE inserter and plugpack.
Recently I plugged a wAP (of similar vintage) into an 802.3af/at switch and I was surprised that it works. Before I had used the PoE inserter and plugpack but when I moved it, it ended up directly on the switch and it still worked
Just compared the specs of those devices. Could indeed be the case.
But something is wrong there with those specs. Map Lite is listed as not having USB powering option which it certainly has. I have 2 in front of me and that’s more or less the only way I power those !
And I never noticed cAP Lite should have it according to specs (why would it ??).
Anyhow, I know that mAP Lite can also be powered using 802.3af/at (at least the ones I have).
And passive PoE as well.
Downgrade version 6.48.6 or earlier. I did a lot of tests with various switches and indeed after uploading the newer version of MAP Lite it does not run via POE-in. Only going back to the older versions fixes the problem and everything works as it should.
I have the same issue with POE not powering on a bunch of brand new CAP Lites. Did you happen to find a solution other that downgrading below 6.48.6?
I have several CAP lite (RBcAPL-2nD) that have been working for several years (since 2019).
This morning, one of my Wifis was not working, and I found that one CAP lite stopped working. I tried connecting it to another port on the POE switch, but it was still not working. After connecting the power supply via the USB port, the AP started up, so I also connected the ethernet without POE and the AP worked, but not via POE. Something went wrong at night. I didn’t see anything suspiciously burnt on the printed circuit board, but I would like to know which components are critical, maybe it needs to be repaired, a transistor may be faulty. I understand electronics, I also have an SMD kit, but without a tip what to check, it’s a waste. Maybe a schematic diagram would help, at least the POE power supply part.
Thank you
I have the same problem, but with a UAP-AC-HD
Without a schematic it is difficult, as PoE has that magic detection/power-up sequence that is difficult to debug.
