I bought a new cap lite and after I reset all the configuration the AP reboot and stopped responding
1- Power led is ON and other 3 LEDS light are off
2- Not accessible via NETINSTALLER
3- I turn off the device press reset button and wait for 15 seconds and it is not show up on netinstaller
4- I connected directly to my computer and from wireshark I found out that after while I am pressing reset button the AP send BOOTP bootable request from it mac address with source IP 0.0.0.0
5- I configure DHCP/TFTP and tried again the AP is getting an IP and ask for vmlinux file and then it stopped
6- I think If I manage to reboot it via PXE it might work
anyone can help me to restore the AP ??
Stopped responding to what?
Did you reset to defaults or to no configuration ?
it stopped responding to anything and only the power light it up and the other led light are off.
I reset the configuration from system → reset configuration after that a pop start and ask if i want to reset all the configuration
