Hi
Can anyone please confirm for me that the cAPlite supports Mode A poe input - that is 48v with +12 and -36
I dont want to power it with mode B which uses +45 -78 as it is old 2-pair cat5 cable so need to use the same pairs for power and 100mbit data.
The spec sheet says it supports 802.11af/at but doesnt specify the POE mode.
Thanks for your assistance
tdw
May 24, 2023, 9:30pm
2
802.3af/at powered devices should accept both Mode A and Mode B with either polarity according to the standards, however Mikrotik PoE-in support is frequently not fully compliant.
From https://wiki.mikrotik.com/wiki/Manual:TOC/MikroTik_POE_in_compatibility_table it appears a cAP lite will work if you use an MDI-X crossover cable or adapter.
Thanks - thats the chart I was looking for.
The Crossover cable is an interesting one. But I can make it work
Thanks again for your help - I really appreciate it.
